It would be very nice to make a TOH with several add-ons to ease photograpy:
Just a dream, until I find some time…
-Vertical and horizontal Kodak screw threads for tripods (night shooting with long pause)
-A lens(es) on hinge(s), that could unfold and come in front of the lens (longer focals)
(like the ones seen here)
-Terminal blocks for a wire for remote triggering (well, perhaps a bit aged tech…)
-A foldable led ring to deploy around the lens
-retractable accordion sunshade
-Flash filters: green correction + daylight, green correction + 2700°K
For the tripod. Would it make sense to use some magsafe adapter? That could keep the TOH slim. Screws are possible too, but the length of the threads directly translates to thickness.
The thing is, changing the back is delicate.
I’m always afraid to break some fixing bits.
I wouldn’t do it every time I want to make a picture.
Having a magnetic/metalic ring permanently on the back, as on @thejiral TOH, is interesting.
This allows to snap to a dedicated TOOH in one second.
The TOOH could then, have all photo gadget we like.
The Other Third would then become a more appropriate name than The Other Other Half. xD
@nephros, were you referring to these Gopro boxes with all the mountings?
Thanks, I see.
That’s good for a solid constant installation. Stable, won’t move.
None the less, a tripod is still needed as, for each take, one might want to easily and precisely adjust the field.
An on-phone direct TOH is perhaps not the correct approach for photo. @thejiral idea, TOT, or just a good [phone holder-to-tripod] thing would probably be better.
I DIYed a TOH for my iPhone with a filter attachment and standard attachment screw, very very useful but only stable because it’s a screwed together, thick metal case.
