Whenever I enable autostart of OSM Scout Server It’s set back to disabled. What am I doing wrong? Do others have similar problems?
I Installed latest version via Chum.
Do you mean the setting “ Automatic activation”? Have you swiped left to accept the setting instead of swiped right like it’s done in most apps?
I have swiped left and right and clicked on accept. But everytime I enter setings again, automatic activation is disabled again. The systemd config files are all there.
Is that only a UI issue or does the service really not autostart?
It doesn’t start as well, so not only a UI issue. I now start the server, everytime the screen is on with situations. This works, but consumes at least a bit more battery than necessary.
