After updating to the latest 3.4, I noticed OSM Scout Server (needed for Pure Maps) no longer worked. I did a clean flash/update and it wouldn’t install from Storeman, due to a version discrepancy in libicui. I needed OSM Scout Server (and Pure Maps) because I don’t like the Android solutions. I figured out a way to get OSM Scout Server installed and running perfectly. Please note, this may not be the most ideal way to do it, but it WORKS!
Symlink the existing version of libicui to the version required for OSM Scout Server (this isn’t ideal, but I’ve noticed no bad behavior or issues):
devel-su
ln -s /usr/lib/libicui18n.so.66 /usr/lib/libicui18n.so.63
ln -s /usr/lib/libicudata.so.66 /usr/lib/libicudata.so.63
ln -s /usr/lib/libicuuc.so.66 /usr/lib/libicuuc.so.63
Download OSM Scout Server:
curl -C - --output osm-scout-server.rpm https://openrepos.net/sites/default/files/packages/6933/harbour-osmscout-server-1.17.0-1.132.1.jolla_.armv7hl.rpm
Install the RPM:
rpm -i --nodeps osm-scout-server.rpm
You’ll need to do the same for mimic, to get text-to-speech working for turn by turn navigation. Download mimic:
curl -C - --output mimic.rpm https://openrepos.net/sites/default/files/packages/6933/mimic-1.2.0.3-1.9.1.jolla_.armv7hl.rpm
Install it:
rpm -i --nodeps mimic.rpm
I’ve tested everything very thoroughly, and I finally have an offline maps solution working on 3.4. Please let me know if this helps you, or if you have any further questions. Enjoy!
