I always have been curious about Tor. Often use it. I want to try it on my Jolla Phone (2026) and i see a few options:
The Tor (aarch64+armv7ht) option
The android options (F-droid Guardian project, Tor browser or Orbot
I’d rather not us the android options, because i want to reduce android to a minimum.
But I find the Tor (storeman) option rather difficult and, may i say, a little tedious?. I took a few steps in qcommand and the terminal, but it feels if i’m going to brick my phone.. So i took a pause.
I remember on the N900, N9 and as i recall also on the Jolla phone 1 (early versions of sailfish) that you could install it with even a toggle in the drop-down-menu to turn it on and off.
I want to use it, but i’m not really a terminal-app/service-starting kinda guy. Maybe something has changed in sailfish that an easy way is not possible anymore, i don’t know.
But is there a change this could get easier? I mean, i see new apps popping up every day now.
Hope you can give me some insights. Thanks!
PS: I’m not sure if this topic belongs in Applications or Feature requests. If i must change it, let me know.
qcommand is a solution for non terminal guys. Should you do not use root option a chance you can break something is close to none.
There is nothing tedious in this solution. I find making a special app only for starting/stopping one service behind a start/stop buttons a tedious solution but it looks like the time for tedious solutions has already come.
I already asked this in the German thread but got no replies:
Shouldn’t it be possible to create a VPN config for Tor, that can then be registered via Settings => VPN? So that all network traffic runs through that?
This is not the main issue and there is already a place to set global proxy for tor without any of such VPN gimmicks in Settings->WLAN->Advanced. That is already explicitly written in openrepos tor description.
The main issue is there is now way to start tor service without additional runners from qml.
