Noobie UI Questions
Dear All
I have some questions that I hope you all can help me with. I did my due diligence with the search function but to no avail.
  1. How can I remove a notification (singular)?
    Swiping left / right doesn’t help, it just goes back to my home screen. Long click gives me the option to remove all notifications, what if I solely want to remove one?
  2. How can I select multiple images / documents / etc. from the file manager(s)?
  3. How can I set a different lock and home screen pictures?
  4. How can I search for installed apps? As in from the app drawer, being able to type and live filter the displayed apps would be great.
  5. Is there any way to have the minimized apps also show the app icon? This would be extremely helpful when many apps are open at the same time, especially Android Apps as it renders the window itself, making it hard to determine what the minimized app really is.
  6. Is there any way on how to get folders with custom icons? I am fine with some modding tweaking.
Thanks a bunch
Your intuition is very good - it is long-press and swipe.
Depends on the file manger or app in question. For gallery you just enter select mode with the pulley menu and select however many images you want.
That doesn’t necessarily mean you can share multiple files after that - not all share functions take multiple files.
Forget about it.
There is no built in functionality for this. Some app probably exists.
This has been asked before - search and you shall find.
Strangely longtime users does not have this issue/preference.
Probably not.
Klick the square hamburger… and then you can swipe them away one by one.
  1. Create ambience of any picture of choice
  2. Patchmager patch
  3. Patchmanager patch
Install patchmanger via openrepos. Think its too much to get you in here. PM me an Ill help you out..
Greetings and welcome abroad
Several apps/patches actually.
Of course there is. You can modify any icon (by hand) if you wish. But they are not persistent through system upgrade, so to make it a bit quicker, I made a RPM to replace my wanted icons.
You misunderstand the question. It is about different pictures on different screens.
But for folders [of apps]?
Yes, just replace the system ones.
For JP26…
/usr/share/themes/sailfish-default/silica/z1.5/icons
I guess i’m thick… but those icons you indicate doesn’t look very replaced - let alone individually.
Of course they are replaced, or do you find them in your folder settings?
I don’t use folders. So i guess good job on making them look stock.
No I didnt, but thx for youre assuming… Then you can gave the better answer; -) then in the end, to edit the background (not seperately but at least at all) ambience is the answer
Well, I did that in 2014 already. :wink:
It very clearly says:
Ok then :+1:. OP takes what fis to them
Thanks all for the swift help! Will try and report back.
Also look at the Launcher Combined patch for app folders icons made of up to 9 app icons that are in the folder (see images in the link)
Trying to summarize the results, thank you all once again.
    ”long-press and swipe”
    Ah, now it feels intuitive, not sure why it didn’t occur to me. Maybe something for the tutorial to add?
    Limited support depending on the app / picker
    Not a feature yet
    I have figured out how to crop the images first, so the result when setting a ambience is as expected.
    @carepack will pm you. thanks!
    Yes possible, they are loaded from a folder and can be replaced / edited
    @eson it may seem simple for you, but I first have to figure out how to ssh to the device and what format these icons have. but good to know it is possible, as i don’t like the default set. they aren’t very easily to tell apart imho.
Huge thanks for this! I have been looking for exactly this folder function and somehow missed this one!
If using the “File Browser” app, tap the file’s icon, rather than the filename.
Goto Settings -> Developer Mode -> Enable Developer Mode and then enable Remote Access (or what ever it is in English/your chosen UI language). After that you not only have ability to SSH to your phone, but also the Terminal app on your phone.
