REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.58
HARDWARE: Xperia XA2 dual-sim
UI LANGUAGE: Swedish
REGRESSION: ?
I have hit an interesting bug, which, from the UI behaviour, looks like there was some decision made here.
My friend’s WiFi network has the letter ä in the password. When I input that into the password input field the “Connect” button becomes inactive.
No other device has any problems connecting to that network.
I have tested it with some other accented letters and it seems any of them will trigger this bug.
A wireless network with strange enough password.
But you can actually test it on any wireless network, just input enough characters for the “Connect” button to become active and then enter any non-English accented letter.
- Open the “Connect to internet” view from top menu
- Pick a WiFi network
- Enter password containing a non-English accented letter
The “Connect” button stays active and allows to connect to the network.
The “Connect” button deactivates and connection is impossible.
Chum and Storeman installed, developer mode enabled.
Patchmanager installed with following patches applied:
- Force cover size
- Sandbox indicator
- Finer volume control
- Disable launcher pagination
Clockwork installed with N9ish icons pack and some custom ones.
