For some time (maybe last SFOS update … that I do not know), I do not get any mobile connection on my XperiaXA2. Everything else works as expected. I tried a different SIM card to no avail, I tried the SIM card on my XperiaX SFOS mobile device: It works. It used to work before on my XperiaXA2. Restarting did not help, reflashing the phone with SFOS did not work. Any thoughts?
I reflashed 4.1.0.24 → no connection
Now I am on 4.3.0.15 → no connection:
I restarted ofono service and here is the status after restart:
[root@XperiaXA2 journal]# systemctl status ofono
● ofono.service - Telephony service
Loaded: loaded (/usr/lib/systemd/system/ofono.service; disabled; vendor preset: enabled)
Active: active (running) since Sun 2023-04-30 10:55:43 CEST; 2s ago
Main PID: 7372 (ofonod)
Memory: 920.0K
CGroup: /system.slice/ofono.service
└─7372 /usr/sbin/ofonod -n --nobacktrace --noplugin=,he910,dun_gw_bluez5,hfp_bluez5,cdma_provision,isimodem,n900,u8500,qmimodem,gobi,cdmamodem,isiusb,nwmodem,ztemodem,iceramodem,huaweimodem,calypsomodem
,swmodem,mbmmodem,hsomodem,ifxmodem,stemodem,dunmodem,hfpmodem,speedupmodem,phonesim,telitmodem,udev,udevng,bluez4,dun_gw_bluez4,hfp_ag_bluez4,hfp_bluez4,dun_gw_bluez5,hfp_bluez5Apr 30 10:55:43 XperiaXA2 ofonod[7372]: Excluding Phone Simulator driver
Apr 30 10:55:43 XperiaXA2 ofonod[7372]: Excluding CDMA AT modem driver
Apr 30 10:55:43 XperiaXA2 ofonod[7372]: Excluding External Hands-Free Profile Plugin
Apr 30 10:55:43 XperiaXA2 ofonod[7372]: Excluding Dial-up Networking Profile Plugins
Apr 30 10:55:43 XperiaXA2 ofonod[7372]: Excluding CDMA provisioning Plugin
Apr 30 10:55:43 XperiaXA2 ofonod[7372]: Initializing RIL binder transport plugin.
Apr 30 10:55:43 XperiaXA2 systemd[1]: Started Telephony service.
Apr 30 10:55:43 XperiaXA2 ofonod[7372]: [gbinder-radio] Connected to android.hardware.radio@1.1::IRadio/slot1
Apr 30 10:55:43 XperiaXA2 ofonod[7372]: slot1 version 101
Apr 30 10:55:44 XperiaXA2 ofonod[7372]: SIM card OK
Then I removed the SIM card and inserted it again and here is the status after that (no restart yet):
Active: active (running) since Sun 2023-04-30 10:55:43 CEST; 1min 52s ago
Memory: 924.0K
,swmodem,mbmmodem,hsomodem,ifxmodem,stemodem,dunmodem,hfpmodem,speedupmodem,phonesim,telitmodem,udev,udevng,bluez4,dun_gw_bluez4,hfp_ag_bluez4,hfp_bluez4,dun_gw_bluez5,hfp_bluez5Apr 30 10:55:43 XperiaXA2 ofonod[7372]: Excluding CDMA AT modem driver
Apr 30 10:57:20 XperiaXA2 ofonod[7372]: No SIM card
note the “No SIM card” at the end. So appearantly the phone recognizes the SIM card but for some reason it is not requesting unlocking it, i.e. entering the PIN code.
Any thoughts?
airplane mode on/off did also not help.
As I am on Linux using EMMA to reflash to Android is not an option.
Thanks.
Edit: I updated to 4.4.0.72 → still no mobile connection
I checked logs of ofono and the only suspicious I see is:
ERROR! Failed to add inotify watch /run/ofono/ril.ecclist mask 0x000a: Permission denied
When I do “systemctl restart ofono” the logs say
Apr 30 12:04:30 XperiaXA2 systemd[1]: Stopping Telephony service…
Apr 30 12:04:30 XperiaXA2 ofonod[2929]: Terminating
Apr 30 12:04:30 XperiaXA2 ofonod[2929]: Exit
Apr 30 12:04:30 XperiaXA2 systemd[1]: Stopped Telephony service.
Apr 30 12:04:30 XperiaXA2 systemd[1]: Starting Telephony service…
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: oFono version 1.28
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding udev hardware detection
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Novatel modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Sierra modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding ZTE modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Icera modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Huawei modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Calypso modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding MBM modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Telit modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding HSO modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Infineon modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding STE modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Dialup modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Hands-Free Profile Driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding SpeedUp modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Phone Simulator driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding CDMA AT modem driver
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding External Hands-Free Profile Plugin
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding Dial-up Networking Profile Plugins
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Excluding CDMA provisioning Plugin
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Initializing RIL binder transport plugin.
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: Initializing AML plugin.
Apr 30 12:04:30 XperiaXA2 systemd[1]: Started Telephony service.
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: [gbinder-radio] Connected to android.hardware.radio@1.1::IRadio/slot1
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: slot1 version 101
Apr 30 12:04:30 XperiaXA2 ofonod[7519]: SIM card OK
