Nextcloud account doesn’t have sync enabled by default
REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.72
HARDWARE: Xperia 10
UI LANGUAGE:Polish
REGRESSION: no idea
By default NextCloud synchronization is disabled. User need to enabled it but when creating account he’s not even aware of it, cause the only place where sync can be enabled is after adding Nextcloud account
and only then during edit.
There should be option to set sync interval while adding account which would be the best, or some default option for sync should be set or at least information while adding account that user must manually set sync intervals.
NextCloud account
  1. Add NextCloud account into the system
  2. upload file to the nextcloud share
file will be shown in the gallery under nextcloud “view”
file is not shown
Not related
User need to edit freshly added account and enable synchronization
This bug is related to: Nextcloud in gallery doesn't show shared file
Linked to an already existing bug in internal bug tracker
