Need help with file access for android files
I recently got the new jollaphone (2026) and I wanted to manually transfer some android files from my old phone on my PC to my new phone.
When I connected my jollaphone to my PC and in the file explorer went to the following address: “This PC\Jolla Phone (2026)\Mass storage\android_storage\Android” I noticed that the file was empty.
When I went to this file on my phone I got the following message: “No permission to access /home/defaultuser/android_storage/Android”.
So my question is: how do I get access to view and edit these files?
Do you want to edit files on your phone using your computer or on the pbone itself?
On the phone file explorer from open repos is unrestricted.
Of you mount your telephone as root or.via MTP you should also be able to write and overwrite files.
I would like to edit files on both my computer and phone.
I did put the USB on MPT but I haven’t tried to mount as root. How do I do that?
I am also trying to figure out the root login with terminal/SSH from linux. No info found, just for C2 atm. I find it weird that Jolla says we have full control of the phone, but such information is withheld.
You set the pw and all SSH-related things in Settings - Developer tools.
It is documented here:
What are you on about?
This doesn’t differ between phones at all.
