Mount USB (NTFS) drive
Is it possible to mount an NTSF formatted USB drive (Samsung T5)?
As I also use it to transfer data to Windows PCs (work/family) it is formatted NTSF/exFAT. It mounts automatically in Linux Mint and Android but the J2 does not react at all. It also is not shown in the drives setting.
Is this an issue of the formatting or the drive? I don’t want to format it (yet) ext4 just to try out, whether it is seen by SFOS.
According to my forum search, USB OTG should work out of the box and the drive should be shown in the drives setting, ready to be mounted.
To my knowledge, Linux does not natively support NTFS as it is proprietary to Microsoft. You may need something like ntfs-3g, which I personally have not used and which has not been updated in >10yrs (at least, this specific sailfish binary), so may not work too great anymore.
This is not clear, is your drive NTFS or exFat? If the former, my above comment stands. If the latter, it should mount fine. These are two notably different filesystems however so you really must be clear which you are talking about.
I am aware od that. I quickly plugged it into my Linux Mint PC yesterday and looked it up in the drives app/program. It showed ‘NTFS/exFAT’.
I never formatted it, but used it right away out of the box. My Ubuntu Touch phone registered the drive but could not mount it.
I guess I will have to reformat it in the end, which is not too big a problem.
I don’t think it’s a problem of filesystem support:
grep -E 'ntfs|exfat' /proc/filesystems
	exfat
	ntfs
But you’ll probably have to do this manually with terminal commands.
Once you figured that out you can probably make a udev rule that launches a script that mounts it automatically when you plug it in. Or maybe an /etc/fstab entry is enough.
PS: what is “Drives settings” in SfOS?
My bad, I meant ‘memory’ in the system section, where you can (un-)mount the SD card.
Thanks for your answer, I’ll check out the options, not right away though.
I see. It’s “Storage” in the English translation.
There might be one or two useful things in this blog: Articles tagged sailfish os - dt.iki.fi
Yeah, well, I now switched the phones’ main language to English, at least as long as I browse the forums and ask questions. (Pity, you can’t install several languages and just switch. The phone does a reboot)
Thanks for the link, bookmarked! :slight_smile:
If you don’t want to change your phone’s main language, you can launch the Settings app with a different locale by setting the LANG or LC_ALL environment variable. For example, to launch it in english, you can run the following command in the terminal:
LANG=en_US.utf8 jolla-settings
You can list all available locales on your system with:
locale -a
It won’t affect this topic, but starting apps via terminal might affect results because it’s not sandboxed then.
Personally I think switching to English for a while is a small price to pay for better troubleshooting, esp. since OP’s English is very good.
Thanks for pointing that out. I forgot to mention that this should only be used to check for translations in other locales, not to actually change any settings.
Still trying to mount my USB SSD. I realized, that the “OTG” in the title was misleading, sorry for that. I edited it out now.
According to this documentation (quote: “This article is also valid for external storage device which can be connected with a special USB On-The-Go cable to your Sailfish device”), I need a special USB-OTG cable in order to connect an external drive or USB-Stick.
Actually, this is an external SSD sporting USB-C 3.1 and if I understood correctly, an OTG adaptor is only needed for USB-A thumbdrives (4 lanes, 5 lanes, USB host and all that, according to wikipedia).
I don’t have an OTG cable, and searching for it, only shows cables / devices with USB-A on the secondary side. Still, maybe I am wrong here.
Using a high-quality USB-C cable the drive gets mounted on my PC, Android phone, Ubuntu Touch phone, but not - yet - on the J2.
I tried NTFS, exFAT, ext4 and unformatted. The drive does not show up in the storage app. I took out the SD card, which didn’t help either.
When the drive is plugged in and I start the storage app, it takes ~20 seconds to show up, or it crashes. Otherwise it starts within 1-2 seconds, but you know that.
I am a complete amateur, when it comes to Linux, so bear with me…
I connected to the phone through ssh.
The drive being formatted ext4.
Running lsblk shows sdd without a mount point, when the drive is connected. This is not shown, when the drive not connected. The section around sdd looks like this:
├─sdc71                                         259:55   0 232.4G  0 part
│ ├─sailfish-root                               254:0    0   9.8G  0 lvm   /linkerconfig
│ └─sailfish-home                               254:1    0 222.6G  0 lvm
│   └─luks-94c65437-947a-41c8-ac64-9b3e94d9e3b4 254:2    0 222.6G  0 crypt /home
├─sdc72                                         259:56   0   256M  0 part
└─sdc73                                         259:57   0    16M  0 part
sdd                                               8:48   0 931.5G  0 disk
nbd0                                             43:0    0     0B  0 disk
Running dmesg | grep ssd, after the drive was plugged in - unplugged - plugged in once more.
\[defaultuser@JollaPhone2026 \~\]$ dmesg | grep sdd
\[133119.474208\] \[ T4523\] sd 1:0:0:0: \[sdd\] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
\[133119.474595\] \[ T4523\] sd 1:0:0:0: \[sdd\] Write Protect is off
\[133119.474623\] \[ T4523\] sd 1:0:0:0: \[sdd\] Mode Sense: 43 00 00 00
\[133119.475204\] \[ T4523\] sd 1:0:0:0: \[sdd\] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
\[133119.475464\] \[ T4523\] sd 1:0:0:0: \[sdd\] Preferred minimum I/O size 512 bytes
\[133119.475486\] \[ T4523\] sd 1:0:0:0: \[sdd\] Optimal transfer size 33553920 bytes
\[133119.496482\] \[ T4523\] sd 1:0:0:0: \[sdd\] Attached SCSI disk
\[133173.358764\] \[ T5987\] sd 1:0:0:0: \[sdd\] Synchronizing SCSI cache
\[133173.678461\] \[ T5987\] sd 1:0:0:0: \[sdd\] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=DRIVER_OK
\[133201.048865\] \[ T4544\] sd 1:0:0:0: \[sdd\] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
\[133201.049271\] \[ T4544\] sd 1:0:0:0: \[sdd\] Write Protect is off
\[133201.049297\] \[ T4544\] sd 1:0:0:0: \[sdd\] Mode Sense: 43 00 00 00
\[133201.049963\] \[ T4544\] sd 1:0:0:0: \[sdd\] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
\[133201.050220\] \[ T4544\] sd 1:0:0:0: \[sdd\] Preferred minimum I/O size 512 bytes
\[133201.050243\] \[ T4544\] sd 1:0:0:0: \[sdd\] Optimal transfer size 33553920 bytes
\[133201.072125\] \[ T4544\] sd 1:0:0:0: \[sdd\] Attached SCSI disk
\[133211.328039\] \[ T4544\] sd 1:0:0:0: \[sdd\] Synchronizing SCSI cache
\[133229.450119\] \[ T5987\] sd 1:0:0:0: \[sdd\] Synchronizing SCSI cache
Running dmesg is a bit weird, as it takes up to 30+ seconds to return a result. However, running the crest app, keeps things snappy (output shows up after ~ 5 sec, while dmesg shows 100% in crest)
dmesg|tail is a too short, dmesg -W does not work as expected, it just throws the whole thing at me. Well, sifting through this, I stumbled across the following snippets:
\[134766.896253\] \[ T7374\] usb 1-1: New USB device found, idVendor=04e8, idProduct=61f5, bcdDevice= 1.00
\[134766.896712\] \[ T7374\] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
\[134766.896762\] \[ T7374\] usb 1-1: Product: Portable SSD T5
\[134766.896800\] \[ T7374\] usb 1-1: Manufacturer: Samsung
\[134766.896836\] \[ T7374\] usb 1-1: SerialNumber: …
\[134766.907904\] \[ T7374\] scsi host1: uas
\[134766.911548\] \[ T6941\] scsi 1:0:0:0: Direct-Access     Samsung  Portable SSD T5  0    PQ: 0 ANSI: 6
\[134766.921641\] \[ T7589\] sd 1:0:0:0: \[sdd\] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
\[134766.922060\] \[ T7589\] sd 1:0:0:0: \[sdd\] Write Protect is off
\[134766.922089\] \[ T7589\] sd 1:0:0:0: \[sdd\] Mode Sense: 43 00 00 00
\[134766.922618\] \[ T7589\] sd 1:0:0:0: \[sdd\] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
\[134766.922908\] \[ T7589\] sd 1:0:0:0: \[sdd\] Preferred minimum I/O size 512 bytes
\[134766.922933\] \[ T7589\] sd 1:0:0:0: \[sdd\] Optimal transfer size 33553920 bytes
\[134766.946546\] \[ T7589\] sd 1:0:0:0: \[sdd\] Attached SCSI disk
As a comparison, running dmesg -W on my PC and plugging in the drive shows this:
\[35710.263341\] usb 4-1: new SuperSpeed USB device number 9 using xhci_hcd
\[35710.305202\] usb 4-1: New USB device found, idVendor=04e8, idProduct=61f5, bcdDevice= 1.00
\[35710.305217\] usb 4-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
\[35710.305224\] usb 4-1: Product: Portable SSD T5
\[35710.305229\] usb 4-1: Manufacturer: Samsung
\[35710.305234\] usb 4-1: SerialNumber: …
\[35710.314609\] scsi host6: uas
\[35710.315458\] scsi 6:0:0:0: Direct-Access     Samsung  Portable SSD T5  0    PQ: 0 ANSI: 6
\[35710.316586\] sd 6:0:0:0: Attached scsi generic sg2 type 0
\[35710.317307\] sd 6:0:0:0: \[sdc\] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
\[35710.317438\] sd 6:0:0:0: \[sdc\] Write Protect is off
\[35710.317448\] sd 6:0:0:0: \[sdc\] Mode Sense: 43 00 00 00
\[35710.317674\] sd 6:0:0:0: \[sdc\] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
\[35710.363328\] sd 6:0:0:0: \[sdc\] Optimal transfer size 33553920 bytes
\[35710.370695\] sd 6:0:0:0: \[sdc\] Attached SCSI disk
\[35710.651834\] EXT4-fs (sdc): recovery complete
\[35710.658448\] EXT4-fs (sdc): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none.
Why does the phone not mount the disc?
edit: formatting
Please surround output such as dmesg with three backticks, it makes it much more readable.
some stuff
For me it looks like the system does mount the drive just fine. (e.g. the last line of dmesg sais that).
You can confirm with
cat /proc/mounts
Question is why does it not appear in Storage.
One thing you could try is to put a partition table on it. Currently it looks like the whole drive is one filesystem without partitions. (shows e.g. sdc, not sdc1).
If it works afterwards, I’d say that’s a bug in Storage.
Thanks for your support!
Here is what I did:
Create a partition table and three partitions ext4 / exFAT / NTFS
(unrelated, but still: Ubuntu Touch mounts ext4 and exFAT, it sqeaks at NTFS)
Connect it to the Jolla phone, the symptoms are the same: Storage app stalls, does not show the drive and also loses the SD card.
Looking into dmesg:
[159899.540476] [T24559] sd 1:0:0:0: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[159899.540822] [T24559] sd 1:0:0:0: [sdd] Write Protect is off
[159899.540841] [T24559] sd 1:0:0:0: [sdd] Mode Sense: 43 00 00 00
[159899.541329] [T24559] sd 1:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[159899.541563] [T24559] sd 1:0:0:0: [sdd] Preferred minimum I/O size 512 bytes
[159899.541581] [T24559] sd 1:0:0:0: [sdd] Optimal transfer size 33553920 bytes
[159899.595600] [T24559]  sdd: sdd1 sdd2 sdd3
[159899.596448] [T24559] sd 1:0:0:0: [sdd] Attached SCSI disk
[159910.017955] [T24497] sd 1:0:0:0: [sdd] Synchronizing SCSI cache
(… and 46 more lines of Synchronizing SCSI cache)
lsblk:
[defaultuser@JollaPhone2026 ~]$ lsblk
├─sdd1                                            8:49   0 310.5G  0 part
├─sdd2                                            8:50   0 310.5G  0 part
└─sdd3                                            8:51   0 310.5G  0 part
looking up the position of “New USB” in dmesg I found the following
[160204.449620] [T24421] usb 1-1: New USB device found, idVendor=04e8, idProduct=61f5, bcdDevice= 1.00
[160204.449634] [T24561] [VCP] PM_POST_SUSPEND entered 0 1
[160204.449640] [T24421] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[160204.449657] [T24561] [DISP]mtk_drm_vcp_notifier VCP_EVENT_RESUME status(1)
[160204.449663] [T24421] usb 1-1: Product: Portable SSD T5
[160204.449681] [T24561] [dpc] dpc_skip_pm_ctrl:4747 skip_force_power:0, vcp:1,vlp pm mask:0x0
[160204.449694] [T24561] fgauge:fgauge gct system_pm_notify mode1:4
[160204.449703] [T24421] usb 1-1: Manufacturer: Samsung
[160204.449708] [T24421] usb 1-1: SerialNumber: 1234567F372F
[160204.449728] [T24561] fgauge:fgauge gct system_pm_notify 1 4
[160204.449745] [T24561] fgauge:system_pm_notify mode2:4
[160204.449821] [T24561] bm_pm_event: enter PM_POST_SUSPEND
[160204.451206] [T24421] UO, xhci_mtk_alloc_container_ctx(1779) input context (2)
[160204.451246] [T24421] UO, mtk_offload_alloc_mem(493) success to allocate (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.451297] [T24561] [scp_dvfs]: [SCP] [mt_scp_stop_res_prof:2260] [0] susepnd time: 100ms
[160204.451532] [T24421] UO, mtk_offload_free_mem(526) success to free (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.451566] [T24421] UO, xhci_mtk_alloc_container_ctx(1779) input context (2)
[160204.451585] [T24421] UO, mtk_offload_alloc_mem(493) success to allocate (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.451840] [T24421] UO, mtk_offload_free_mem(526) success to free (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.452110] [T24561] [scp_dvfs]: [SCP] [mt_scp_dump_sleep_count:2332] - scp_sleep_cnt_0 = 3430157
[160204.452135] [T24561] scp_audio_pm_event: PM_POST_SUSPEND
[160204.452235] [T24530] conn_pwr_core_resume low_battery=0, thermal=0, customer=0x00000000
[160204.452254] [T24530] conn_pwr_core_resume bt=0, FM=0, GPS=0, Wi-Fi=0
[160204.452280] [T24561] [name:spm&] PM: suspend exit 2026-08-24 19:28:36.624661 UTC;android time 2026-08-24 19:28:36.624661
[160204.452307] [T24561] [btmtk_info] [BGF dump suspend/wakeup] Count = 3
[160204.452326] [T24561] [btmtk_info] 00006262 f006ab58 50200003
[160204.452340] [T24561] [btmtk_info] [bt host info] [0-16] not set
[160204.452352] [T24561] [RSC]rsc_suspend_pm_event+:g_u4EnableClockCount(0) g_SuspendCnt(0).
[160204.452367] [T24561] [RSC]rsc_suspend_pm_event-:g_u4EnableClockCount(0) g_SuspendCnt(0).
[160204.452382] [T24561] [WPE][wpe_suspend_pm_event] wpe_suspend_pm_event: WPE resume g_u4EnableClockCount: 0, g_u4WpeCnt: 0
[160204.452392] [T24561] [FDVT][fdvt_suspend_pm_event] +PM_POST_SUSPEND:clock_enable_count(0), fdvt_count(0)
[160204.452418] [T24561] [FDVT][fdvt_suspend_pm_event] -PM_POST_SUSPEND:clock_enable_count(0), fdvt_count(0)
[160204.452433] [T24561] [MFB]mfb_suspend_pm_event:g_u4EnableClockCount(0) g_SuspendCnt(0).
[160204.452449] [T24561] [DIP][dip_suspend_pm_event] DIP resume G_u4DipEnClkCnt: 0, g_u4DipCnt: 0
[160204.453078] [ T1682] conninfra@(consys_power_state_dump:333) [consys_power_state][round:101073]conninfra:0.089,0;wf:0.094,1;bt:0.095,0;gps:0.101,0;[total]conninfra:410158.907,1801691;wf:433303.575,823350;bt:499452.236,1175989;gps:519202.419,40;
[160204.453113] [ T1682] conninfra@(consys_power_state:177) [consys_power_state] [0xfaf60e09] bgf
[160204.453345] [T24561] timesync host resume boottime 523460625844018
[160204.453395] [T24561] timesync boot 523460625894179 sched 160204453394137 android 08-24 19:28:36.625883
[160204.454615] [ T1682] Consys HW version id(0x02050405), retry(10)
[160204.454643] [T24561] PM: suspend exit
[160204.454691] [ T1682] consys_sema_acquire_timeout_mt6858 start hold semaphore (14), flags=0
[160204.455743] [ T1682] conninfra@(consys_thermal_query_adie6631_mt6858:485) [consys_thermal_query_adie6631_mt6858] efuse:[0xa00000b8][0xa880a800][0x00000000][0x00000000][0x00000000][0x00000000][0x00000000][0x00000000]			thermal dump: [0x10003434][0x370330ff][0x34110001][0x00000000][0xffffffff][0x64040000][0x50b05a10][0x00003434][0x00003434][0x00083434][0x00003434]
[160204.455762] [ T1682] conninfra@(calculate_adie6631_thermal_temperature:394) y=[52] b=[56] constOffset=[25] [0] [0] => t=[23]
[160204.456188] [    C0] usb 1-1: mbrain: idVendor=04e8, idProduct=61f5, bcdDevice= 1.00, speed=3, state=7
[160204.456328] [T24421] UO, xhci_mtk_alloc_container_ctx(1779) input context (2)
[160204.456365] [T24421] UO, mtk_offload_alloc_mem(493) success to allocate (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.456468] [T24421] UO, mtk_offload_free_mem(526) success to free (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.456494] [T24421] UO, xhci_mtk_alloc_container_ctx(1779) input context (2)
[160204.456511] [T24421] UO, mtk_offload_alloc_mem(493) success to allocate (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.456567] [T24709] usb 1-1: mbrain: already stay in state(7) and try to update mbrain db
[160204.456605] [T24421] UO, mtk_offload_free_mem(526) success to free (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.456629] [T24421] UO, xhci_mtk_alloc_container_ctx(1779) input context (2)
[160204.456646] [T24421] UO, mtk_offload_alloc_mem(493) success to allocate (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.456740] [T24421] UO, mtk_offload_free_mem(526) success to free (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.456764] [T24421] UO, xhci_mtk_alloc_container_ctx(1779) input context (2)
[160204.456781] [T24421] UO, mtk_offload_alloc_mem(493) success to allocate (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.456871] [T24421] UO, mtk_offload_free_mem(526) success to free (DRAM, CONTEXT) buf:00000000e21a1032 vir:000000000e3c5a16 phy:0x9f401200 size:1056 is_rsv:1
[160204.457190] [ T3511] yft_pogo_pin_int_state_show yft_pogo_pin_eint_state:0
[160204.458196] [T24421] scsi host1: uas
[160204.460255] [T24517] scsi 1:0:0:0: Direct-Access     Samsung  Portable SSD T5  0    PQ: 0 ANSI: 6
[160204.460658] [T24561] PM: suspend entry (s2idle)
[160204.463887] [T24561] Filesystems sync: 0.003 seconds
[160204.464260] [T24561] [DISP]mtk_drm_pm_notifier PM_SUSPEND_PREPARE, Disabling CRTC wakelock
[160204.464343] [T24561] log_store: write pmic value 0x38, ret 0x0.
[160204.464711] [T24561] mtk_mminfra_pd_callback: enable gce apsrc: 0x1e980048=0x20002
[160204.464727] [T24561] mtk_mminfra_gce_sram_en: not support
[160204.464735] [T24561] mtk_mminfra_pd_callback: enable clk ref_cnt=1
[160204.467658] [T24561] [VCP] reset_vcp: CORE0_RSTN_CLR 6f9fe001 40c000 ff01 ret 0 clk 182000
[160204.467710] [T24561] [VCP] vcp_enable_pm_clk id 5 done 1 clk 182000
[160204.467718] [T24561] [mmdvfs][dbg]mtk_mmdvfs_enable_vcp: ret:0 enable:1 vcp_power:0 idx:3 usage:0
[160204.467730] [T24561] [mmdvfs][dbg]mmdvfs_v3_release_step: mmdvfs_vcp_cb_ready:0 is_ccf_enable:0 ccf_ena_called:1
[160204.467753] [T24561] [mmdvfs][err]mmdvfs_vcp_ipi_send_ex: ret:-110 retry:0 vcp:1 feature_id:5 ready:0 cb_ready:0 slot:0x6f9ff00001030108 vcp_power:1 unfinish func:0x100
[160204.467761] [T24561] [mmdvfs][err]mmdvfs_vcp_ipi_send_ex: rst_clk:0 sync_data:0x0 ts_pm_suspend:160204340464214 ts_vcp_suspend:160204348726752 ts_vcp_ready:160204346805829
[160204.467770] [T24561] [VCP] vcp_disable_pm_clk id 5 entered 1 ready 0
[160204.468296] [T24518] Filesystems sync: 0.004 seconds
[160204.471752] [T24518] sd 1:0:0:0: [sdd] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[160204.472093] [T24518] sd 1:0:0:0: [sdd] Write Protect is off
[160204.472120] [T24518] sd 1:0:0:0: [sdd] Mode Sense: 43 00 00 00
Trying to go the other way, I took out the SD card (formatted by Jolla phone) and hooked it up to my PC.
Gparted shows an MBR partition table, while the SSD is GPT.
So I changed the partition table to MBR, only one partition exFAT this time.
(There seem to be issues about ownership if you format ext4 in another machine, so I went exFAT this time).
lsblk shows sdd|sdd1 as before and cat /proc/mounts shows the same mountpoint (which is unaccessible in the GUI)
Storage app behaves the same, it takes ages to start and the drive is not shown.
Is there anything I could try out, look up and report back?
edit:
removed the section about mountpoint /dev/mmcblk0p1 as this is the SDcard
Have you tried manually mounting it? Sth like this:
mkdir mnt
devel-su mount /dev/sdd1 mnt
(or sdd2 or sdd3)
This is possibe:
[defaultuser@JollaPhone2026 ~]$ devel-su mount /dev/sdd1 /home/defaultuser/TEST_SSD
Password:
[defaultuser@JollaPhone2026 ~]$ cat /proc/mounts
/dev/sdd1 /home/defaultuser/TEST_SSD exfat rw,relatime,fmask=0002,dmask=0002,allow_utime=0020,iocharset=utf8,errors=remount-ro 0 0
[defaultuser@JollaPhone2026 ~]$ cd TEST_SSD
[defaultuser@JollaPhone2026 TEST_SSD]$ ls -l
total 0
-rwxrwxr-x    1 root     root             0 Aug 25 22:19 test2.txt
[defaultuser@JollaPhone2026 TEST_SSD]$ devel-su touch test3.txt
Password:
total 0
-rwxrwxr-x    1 root     root             0 Aug 25 22:45 test3.txt
test2.txt was already present on the SSD
it was possible to create test3.txt from the CLI and it later showed up, when I connected the SSD to my PC
So, yeah, it’s possible, but actually the drive should simply show up in the storage app, just like the SD card does.
Unfortunately I have no OTG cable to test a thumb drive.
Could anybody try a USB stick and look it up in storage?
Maybe it’s an issue with the SSD being USB 3.1 and the phone has a USB 2 port.
My USB drive mounted automatically to /run/media/defaultuser/
Thanks.
USB 2 / 3 ?
USB Stick or some kind of external SSD?
Its a decade old USB3 stick
Edit: I think they all are backwards compatible, they just default to a lower speed.
