Motorola Edge 30 Neo - port from VerdandiTeam
See my post above. 6/128.
So after flashing, check available storage first (and not when installing Angelfish).
Yeah i’m not asking how big the device is, i’m asking how big of a storage sfos reports
Also guys, don’t panic, but zypper ref; zypper dup AND VOLTE CALL REJECTING + SMS SENDING/RECEIVING SHOULD BE FIXED!!!
Please report EVERYONE on the above, i wanna hear for whom it works in what country
zypper dup updated only an ophono package from chum in my case - is this correct?
On German Telekom network, sending/receiving SMS during a call worked. In one case, the call got dropped when the SMS arrived - but I could not reproduce it, and maybe I accidentally activated the cancel button with my cheek.
Rejecting an incoming call and holding an accepted call did not work.
Another small issue: I cannot change the hostname via the “Advanced” menu in WLAN and cellular settings. It always resets back to Edge30Neo.
Oh, and another thing I noticed: when the screen turns off, WLAN also seems to be affected: a wireless SSH session becomes unusable until I turn the screen back on. Is there any way to tune this?
you absolutely under no circumstance should have ofono from chum
no zypper should update ofono-binder-plugin-ext-qti
I didn’t mean during call, just with volte registration
that’s tiniest of issues tho
Fascinating
I think that’s how these new devices achieve such great suspend, by literally turning wifi off lol
I have same issue, didn’t notice it before since I just tested VoLTE things after flashing.
Hmmm… not good :confused:
But I’ll debug it
Yes - it was this package - couldn’t remember the name. (It was pulled from the chum repo, not the magister repo)
Oh, yes. VoLTE was registered.
(Just for the record: me mentioning issues I found does not imply that you should fix them - I just like to document them so others know what to expect.)
It was not pulled from chum repo because it does not exist in chum repo, it was pulled from adaptation-community
(Just for the record, you mentioning issues is invaluable <3)
Oh, you are right. I seem to be really confused today. Sorry for the spam everyone.
I JUST GOT CHOPCHOP GESTURE TO WORK! HYPE!
Bro this forum is trolling me, couldn’t post above message without complaining about forum
GUYS GUYS Sure chop chop works
BUT YOU WOULDN’T EXPECT THAT SAME EXACT CODE ALSO WORKS ON MY 2014 MOTOROLA
HYPE
Rejecting doesn’t work, but call goes to some weird state. I can still answer after trying to reject and call seems to start, but caller phone still thinks its just ringing. No actual connection is made.
I really don’t have ringback tone on outgoing call, just silence before call connects.
SMS sending seems to work ok now.
SMS receiving kinda works. But it keeps receiving first received-in-volte message and network connection dies after that. Sometimes it reconnects to receive it again for few times, eventually it fails to state where SIM cards are not visible in settings. Rebooting whole phone recovers.
Moved SIM card to another phone in VoLTE after that, it received the same messages after delay.
I’m on Telia network in Finland.
I have no clue what that means
Message “Kuuluuko?” was sent only once.
Moved SIM to other phone, it did receive those same messages eventually.
What’s worst is that it works flawlessly for me
I can send and receive, i can hang up incoming call, and I have ringback tone
@fsan06 has send/recv sms and ringback tone but cannot hang up
you have issue with sending sms, no ringback and no hangup
@raphman has sms send/recv, no rejecting, and idk about ringback
EVERYONE HAS SOMETHING ELSE XD
Also @raphman @Simom if you’re using Telegram I encourage you to join my group as it will be much easier for me to help you both
Guys zypper ref; zypper dup and tell me your experience with the gestures (you’ll find them in settings)
Guys thanks to @fsan06 we’ve managed to fix the storage issue with installation zip!
Fetch it from the usual place (verdanditeam.com where you can get all the info about your veranditeam port :wink: )
Work surprisingly flawlessly after reboot - thank you!
:+1: Need to find a way to reactivate my Telegram account first, though.
I also recommend telegram client called Yottagram or something stupid like that, it’s made by some weird polish dude, and might happen to be already installed on your device :smiley:
