MMS Settings revert back to original settings
REPRODUCIBILITY: Yes
OS VERSION: 5.0.0.72
HARDWARE: Xperia 10 III
UI LANGUAGE: English
REGRESSION:
I changed my MMS settings under Settings/MMS access point and when I exit the screen they revert back to the old settings. What can I do to make sure the settings stay as input?
  1. Go to Settings. Then MMS access point.
  2. Change any settings.
  3. Swipe right to return to previous menu.
  4. Enter MMS access point again.
Changes to settings stay
Settings revert.
How do you “exit the screen”? Do you just close the app or go back one page to the mobile network settings page?
couldn’t reproduce it on my jolla c2 running sfos 5.0.0.76 :man_shrugging:
Could you check permissions, group and user of /var/lib/ofono folder and the subfolders “ls -la /var/lib/ofono”? Do not paste the content since it contains some SIM card IDs but check that the user and group are “radio”.
I go back one page. I do not close the app.
Okay then this is really weird and I’m out of ideas.
