REPRODUCIBILITY (% or how often): 100
BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, Xperia 10…): XA2
UI LANGUAGE: Slovak
REGRESSION: (compared to previous public release: Yes, No, ?): yes
Microsoft Edge crashes down in every 1 minute, restart and run for next one minute, then again
N/A
- Start app (Edge)
- working in it
Working in app without crashing the app
app repeats crash down every minute
It begins after upgrade from Sailfish 4.0.x. Also Aliendalvik control doesn’t work correctly (after run Aliendalvik, all of android apps freeze and restart of android app support is needed). App Microsoft edge was updated to the newest version, but after problems installed again in various older versions - no different result, always crashing down. Aptoide (as a new forced Android store) doesn’t work propertly - some apps update ok, some no and aptoide reports errors, so I used aurora store or apkpure app fore downloading and updatin android apps.
