Meshcore is more efficient in routing, as nodes have different roles (repeaters, companions, room servers etc.), so there’s less workload for a single client to handle. But which is “better” may depend on your local community. In my region (Berlin) meshcore is much more widespread.
Only just saw this. I have just finished (more or less) porting my Ubuntu Touch Meshtastic app, Indra, to Sailfish OS. It’s available on OpenRepos.
Thanks, it looks nice. I had some serious problems connecting the app to my RAK4631 but maybe it’s bluetooth problem and has nothing to do with the app itself, so I need to investigate it further..
In app, I’m able to send messages without problem, but fetching received messages takes minutes or I’m not receiving them at all. Messages are confirmed to be delivered on other side.
There is a known issue with Bluetooth, likely an issue in the underlying Rust library. There is an issue on the Indra repo with a bit more info.
Any updates for your app?
If you’re asking about the Bluetooth bug, yes it is finally fixed in the latest version. It was a problem in the Meshtastic Rust library. The RPM is not available on OpenRepos yet on account of it still being stuck in readonly mode. But version 1.5.1 should work for you if want to use it with a Bluetooth device. Beyond that, there are some minor Silica UI updates on the master branch, but this is not yet in a release.
Great! The version 1.5.1 is working very well with bluetooth, thank you very much!
Maybe try to pair it beforehand, I just tried without pairing and it didn’t appear on the list.
What do You mean exactly. If i gi to radios and try the big scan, I see that picture, what I shared before.
I had the device paired in SailfishOS bluetooth settings already when I started the app, so for me it was immediately visible on “Radio Connection” screen, and also when I chose “Begin Scan”. I tried removing the pairing from phone BT settings, and it was not in the list anymore until I paired it again.
Ok, now understiod what you mean, thanks! Will try it.
Yes, on both Ubuntu Touch and Sailfish OS, the radio has to be added as a bluetooth device in system settings before it will show up in Indra.
I see, it works. Great! Thanks.
