OSVERSION: 5.1.0.11
HARDWARE: Fairphone 5 - fp5 - fp5 - 1.0.1.2 - aarch64
UI LANGUAGE: English (US) (user: en_US, os: en_US.utf8)
REGRESSION: no
Three digit temperatures overflow their columns and the degrees symbol wraps around to a third row. See screenshot.
Recent-ish versuin of Sfos weather app
1.Set weather app unit to Fahrenheit .
2.Select a location with forecast temps above 99F.
3. Swipe to events view to observe issue.
EXPECTED RESULTS:
Text should reflow or rescale or otherwise not spill over awkwardly with a third digit in the temp.
ACTUAL RESULTS:
Three digit temps render awkwardly - see screenshot
ADDONS:
- AAS Bluetooth Bridge: no
- Patchmanager: yes
- OpenRepos: yes
- Chum: yes
- Other: none specified
I’ve only tested so far on a Fairphone 5
Pretty sure this is a regression from old version of weather, but I don’t have a screenshot to double check that memory.
I also suspect the same issue would occur with weather units set to Celsius (except that no users have yet survived those conditions to report it…)
Home Encryption: enabled
