Lock volume rockers to media volume
By default, the volume rocker on Sailfish changes the ringtone volume, and only switches to media volume while something is already playing. So you can’t quickly set the volume before a video or audio starts.
For me, ringtone volume is set-and-forget: I pick a level once and use the privacy mode switch when I want silence. If I ever need to change it, the ringtone volume slider is in the Top menu. What I actually want most of the time is to set the media volume before a video or audio starts.
Turns out Sailfish already supports this. There’s just no switch for it in Settings. So here’s a package that adds one.
What it is
Media volume keys adds two ways to switch the volume keys to media volume:
  • Settings → Volume keys → Always control media volume.
  • Top menu toggle “Media keys”: flip it from anywhere. Add it once in Settings → Top menu.
With it on:
  • The volume keys change the media volume even when nothing is playing.
  • During calls they still change the call volume.
  • The ringtone volume stays in Settings → Sounds and feedback and in the Top menu.
  • Turning the volume down no longer switches the phone to silent.
Install
Download the .rpm file from the latest release and open it in the file manager, which installs it. If it refuses, allow untrusted software in Settings first. (Terminal alternative: devel-su pkcon install-local ~/Downloads/sailfish-media-volume-keys-*.noarch.rpm.)
Then close Settings completely and reopen it. Go to Settings → Volume keys
(or use Settings → Top menu and add the Media keys toggle, then switch it on).
Uninstall
Open Settings → Volume keys, tap Uninstall and accept. The volume key behaviour goes back to the default ringtone volume control, and the page and the Top menu toggle are removed. Afterwards, close Settings completely and reopen it.
More
Without the package
In the Terminal app, as the normal user (no root):
dconf write /jolla/sound/force_mediavolume true
Undo:
dconf reset /jolla/sound/force_mediavolume
Tested on my Jolla Phone (2026), SFOS 5.2.0.22 - use at your own risk.
Source & Download
Works. The default behaviour mildly annoyed me for 12 years, so thanks for this. :smiley:
