Location problem
​I have a Jolla C2 with microG installed. If I use an app where location is enabled, it sometimes shows that my location is on the other side of the country from where I actually am. What causes this, and is there any way to fix it?
What does GPSInfo say?
Do you have Early access Pispala 5.1.0.11 in use and BeaconDB selected. If using wifi the home network might locate you based on providers location. I sometimes notice that with my computer at home network.
I assume the same. I have BeaconDB activated and got located in Bavaria - while being in the south of France.
