Can you please confirm you have created the /config/usb_gadget/g1 directory? The error CONFIGFS not detected is resolved by that directory being present on the filesystem in my testing.
I executed the commands, connected the USB cable, the phone beeped two or three times, the connection method menu appeared, I selected MTP, the menu was repeated, I selected MTP again, but the connection did not occur. ![]()
This is not that important, you can put it off, I can live with it. ![]()
[root@Xperia10IV defaultuser]# systemctl stop usb-moded
[root@Xperia10IV defaultuser]# mkdir -p /config/usb_gadget/g1
[root@Xperia10IV defaultuser]# mkdir -p /config/usb_gadget/g1/configs/c.1
[root@Xperia10IV defaultuser]# mkdir -p /config/usb_gadget/g1/strings/0x409
[root@Xperia10IV defaultuser]# systemctl start usb-moded
[root@Xperia10IV defaultuser]# journalctl -u usb-moded -b
-- Logs begin at Thu 2026-08-06 08:22:57 CEST, end at Thu 2026-08-06 08:24:34 C>
aug 06 08:23:39 Xperia10IV systemd[1]: Starting usb-moded USB gadget controller>
aug 06 08:23:39 Xperia10IV usb_moded[15391]: usb_moded 0.86.0+mer69 starting
aug 06 08:23:39 Xperia10IV usb_moded[15391]: init_done -> reached
aug 06 08:23:39 Xperia10IV usb_moded[15391]: CONFIGFS detected
aug 06 08:23:39 Xperia10IV usb_moded[15391]: /sys/kernel/config/usb_gadget/g1/f>
aug 06 08:23:39 Xperia10IV usb_moded[15391]: usb-moded started after init-done;>
aug 06 08:23:39 Xperia10IV systemd[1]: Started usb-moded USB gadget controller.
do you think you will take this further into the 10 series?
i.e. the 10vi/vii for example
Hey! You have CONFIGFS detected now, and no more all bets are off! My research shows it should be working! @juz has also reported it appears to work on his 10V the same way.
As a last-ditch attempt, try zypper ref && zypper dup and reboot and try again when that is done. Maybe my system is more up to date than yours, but I donât think anything should have changed.
Hmm, I donât own any other Xperia besides the 10IV. The only reason I was also able to do the 10V was because the phones are so similar and use the same SoC and kernel.
Perhaps one day if I ever purchase a 10Viii or something to replace my 10IV, but I do not have the desire to purchase a new phone when there is nothing wrong with this one. That said, porting these devices was quite fun! So whatever phone I get next I will certainly try to port as well.
I canât get out of the lock screen after this. It looks like the touch screen stopped working, it doesnât respond to touches.
EDIT: the sounds also stopped working
To make it more precise, I used the commands pkcon refresh and pkcon update
I specifically said zypper ref && zypper dup for a reason. You have updated your modules directory now without reflashing the updated kernel.
Read up at sailfish-on-murray/TROUBLESHOOTING.md at main ¡ sharks-dev/sailfish-on-murray ¡ GitHub to find out in more detail what you have done and how to fix it.
I think such things are normally done via systemd / udev rules and it looks like it applies here:
Thanks, that is certainly a helpful document, and it mirrors the path I have started going down tonight. I plan on making a systemd service that will run a script before usb-moded.wants or something like that. My earlier thinking was that this wouldnât be necessary and it was something wrong in my usb-moded configs, but I am less convinced of that now.
I am still trying to actually work out what I need to do in order to get developer mode to work, but once I have a script that works every reboot to fix developer mode and MTP reliably, Iâll make the service, add it to droid-config-pdx225/sparse at master ¡ sharks-dev/droid-config-pdx225 ¡ GitHub, and push out the update to users to install with zypper ref && zypper dup.
The mobile responds to touches again, my faul (âA word to the wise is enoughâ), but the MPT still doesnât work (I ran the zypper commands and rebooted).
EDIT: Can I delete the previous (old) directory from /lib/modules/?
Glad you managed to fix it.
As discussed, I am working on an easier solution so perhaps wait a moment for now. I have just published a commit that reliably solves the MTP problem using a systemd service as discussed above. In a few days I will push this out to all users, but hopefully I can also push out a fix for developer mode at the same time, weâll see.
Edit: provided you have got the new kernel version correctly reporting in uname -r, yes you can delete the old modules directory.
Okay, of course Iâll wait, I donât mind, I have 10IV for laboratory work.
