LibreLink working on Sailfish
Hi,
I’m very interested in Jolla and Sailfish. There are a few apps I absolutely dont want to live without, as I’d otherwise have to carry extra devices. Does anyone know if LibreLink works on Sailfish?
I have no idea what is this application so could be interesting to have more details. Is this related to “FreeStyle Librelink”? So likely an Android application? I do not have Freestyle gadgets so cannot test.
If it needs Bluetooth, it does not work currently but Jolla will soon provide a package which allows Android application to use Bluetooth connections (apart from Bluetooth audio which already works).
Wow, bad case of customer deception, what in this app is “libre”?
I was interested to look for details based on the name indeed :wink:
Yes, its the FreeStyle LibreLink. It uses Bluetooth and NFC. The NFC is used to trigger the connection between the sensor on my arm and the app. Updates are pushed via Bluetooth when it has a stable connection. Otherwise you have to rescan the sensor.
It wouldn’t be the end of the world if BT doesn’t work, but the NFC is mandatory.
So not many diabetics are using Sailfish :wink:
You are “libre” to use it.
So it will not work, NFC in AAS is not within reach. Problem for Diabetics is that device producers don’t provide open APIs, other wise it would be easy to make native client apps
Thank you for your answer.
It is not a gadget. Well, one can use it for fun, but most of the users need it in cases of diabetes.
The sensor and the system is called “Libre” because it offers much more freedom than having to prick the finger to extract a drop of blood in order to measure the blood sugar level every time the person has/wants to eat something.
With the measured value, another device, or the user, can send the correct amount of insulin to allow assimilation of the eaten carbohydrates.
True that it would be excellent if the protocol were open in order to use them in Sailfish.
In the mean time, let’s hope that bluetooth will work nicely in Android App Support, as well as, perhaps NFC, one day.
There is an open-source Android app, xDrip, that supports LibreLink. It will still have the problem with NFC for Android apps, but since it is open-source there is a possibility to convert it to a Sailfish version by anyone motivated enough.
I could try to make the app but i dont have the Libre device to test if it reads the data or connect correctly.
Oh, when I checked the xDrip project it looked as a very large task to undertake, at least to me, but maybe if you narrow it down to Libre devices…
I have Libre 2+ buttons on my arm and a Xperia 10 II with Sailfish (5.1), so I can be a happy tester.
