Libomemo-c in chum
I’m not sure what gives, but recently @ron282 (I believe) pushed a revert to 0.5.0 after I had done a 0.5.1 and protobuf release. I had asked for clarification, and gotten none. @piggz, I’m not sure what you’ve done, but libomemo-c seems gone? I think that besides kaidan only @nephros is a user?
@ron282 was there an issue with the 0.5.1 library?
Hmm.
It’s still in main, but gone from Testing.
I suspect it’s the effect of a request with “cleanup” which deletes the original package.
I wonder why this was done? It means numerous things no longer build in testing. Well, qxmpp and co. And presumably kaidan.
I did a osc undelete sailfishos:chum:testing libomemo-c now.
Probably by mistake :slight_smile:
I don’t get why it was published in the first placed. It replaces the the update to 0.5.1 and protobuf with the old version.
Revision history can be seen here:
I guess @ron282 didn’t realize there was a newer revision.
The submission message suggests an ‘initial version’.
Anyway you are still maintainer in testing, so you can restore your version in the _service file.
I’m going to do the following:
  1. move my qxmpp foo to the libomemo-c context
  2. clone kaidan into that context
  3. if it works, push the newer version again.
I’m a bit puzzled at why no one reads the review/comments sections.
EDIT: and I wouldn’t want to get into any pushing matches for lack of communication. Took enough time to get the upgrade to work in the first place.
apols if i messed sonething up. ping me on irc later if needed
will do. I’ll try to sort it out.
I am trying ti use kaidan actually
What are you referring too? qxmpp, omemo-c? All the bits where there and now we have a number of broken builds on testing, including kaidan.
While it’s very unfortunate, I guess the fix is just to revert/update the _service file.
And maybe move the ‘authoritative’ fork to sailfishos-chum org, and work together there?
Nah, it’s gotten more complicated. I had originall adaped qxmpp to use @ron282 fork which it appears he’s been updating. That doesn’t take into account the changes that happend to omemo 0.5 and 0.5.1 and and. I’m looking to see if I can make an adjustment (qxmpp decpendancy issue, naming), otherwise, I’m going to wash my hands of it.
EDIT: my original packaging, for ron, had included pkg configuration with the name changes (libomemo-c-devel, not omemo-c-devel accounted for). I’ve updated this and am seeing if we get back to where it was.
Sorry, i am user of kaidan not of all that stuff that you are speaking about.
Ok, I see. From chum? It seems to build in main but is broken in testing.
From Openrepos, installed and today updated via Storeman
Ok, @ron282 @nephros @piggz I’ve done the necessary changes to rons’ qxmpp and now we have the latest versions of omemo, protobuf-c and ron’s kaidan building on obs.
I believe it was worth it to make the v0.5.1 update to omemo since it’s the only way to track Dinos’ upstream changes and it is a crypto library, after all.
Currently at Show home:poetaster:omemo - SailfishOS Open Build Service
Minial changes to ron’s qxmpp spec:
I would prefer to not push anything seeing as what happened the last time it wasn’t communicated.
