Launcher Combined (fork) patch doesn't work
REPRODUCIBILITY:
OS VERSION: 5.2.0.18
HARDWARE: JP2
UI LANGUAGE: Dutch
REGRESSION:
After the update of sfos, an update appeared for the Launcher Combined Patch for this OS version. I installed it but it doesn't show the icon options when trying ti change a folder's icon
A Jollaphone 2026 (JP2) with OS update to 5.2.0.18
Patchmanager installed.
Update in patchmanager for this patch installed.
  1. Update the OS to 5.2.0.18
  2. Update the patch “Launcher Combined patch (fork)” in patchmanager
  3. Restart the startscreen from within patchmanager or reboot the phone
I should be able to change the icons to those proposed by the patch (as it worked on my other devices and on the previous OS version 5.2.0.17)
I'm unable to choose from those folder icons, only the classic pre-installed jolla icons show.
Patch are unofficial. I moved the category to General.
You are missing step 1.1: Re-install Patchmanager.
https://github.com/sailfishos-patches/patchmanager/issues/521
Thx that worked! Solved
