JP 2026 Upper speaker doesn't work anymore
I received my JP2 on 27.07.26 and speaker got unfunctional on 07.08.26. I can not hear anything from speaker on incoming or out going calls, not even calling beep sounds. The speaker is totally dead. Peaope can hear me but nota sound on my speaker. I wrote to support on 09.08 and still waiting an answer. Anybody has the same problem?
REPRODUCIBILITY:
OS VERSION:
HARDWARE:
UI LANGUAGE:
REGRESSION:
Routine question: Have you tested it with csd tool?
I used to encounter this on old J1, gentle squeezing around the speaker would help. But of course on the new phone (withoutout mechanical damage) that shouldn’be.
Thanks for the tip.
I have tried squeezing a bit gently but didn’t help. I don’t think that physical demage/chock is the issue, because I have never dropped my phone on the floor or something like that.
About CSD Tool…. I didn’t know about it until your message. I looked up on google and find #*#*310*#*# dialing. I did, I could see “The service request started” on the screen but got a message of “There is a problem with the service request”, and no results.
The * and # are mixed up there, just the other way round. Forum software seemingly doesn’t allow me to write it :slight_smile:
Or settings → information-> tap build number five times
Also try to restart the audio subsystem in Settings → Info section → Utilities
I have found out how to write on command line. I turned developer mode on and run CSD from command line. If above speaker means “Receiver Playback” on the system then it gives Fail. I can not hear any playing music. So I think I have an hardware issue….
I had tried restarting the audio system several times and I did also factory reset before. Didn’t help either.
Thanks a lot for your help..
