I would prefer using Jollas native browser, but is seems that it’s no longer supported. Actually it doesn’t run any longer (can’t start it since a day or 2). Does anyone experience the same difficulty? Do we know the status of its (continuing) support?
Native browser in 5.2 is Firefox version 115 based which is still supported upstream. Version 153 is in the works. So where do you get the idea that it’s not supported?
You should rename your topic then.
Do you by any chance have set another website as default for the browser?
yes I did actually. Seems ypu know that it causes trouble? How to repair it? Through settings?
It is only a wild guess. Some websites can crash the browser. Maybe try setting a blank page to the browser in the settings.
Start browser, minimize it ASAP. Press + on cover-page and type something.
if browser refuses to start, just refresh homescreen: Settings→ Utilities (or restart)
Last time someone came in here saying the browser didn’t work, they had basically terraformed their whole home directory and could not fathom that it would have consequences.
What did you do when it broke? It will not fall over on its own.
Well, I for one haven’t terraformed my $HOME and after a given amount of closing and re-opening the browser it just fails to do so. Started w/ 5.2.0.18, IIRC.
Same for me on my C2. Browser freezes after a few seconds of usage and almost since I bought it (I was among the 1st buyers) -I think I tried to reinstall the browser etc with no luck but didnt want to reset the phone at the time. It didn’t bothered me as I moved to Fennec and then moved to JP26 where I can finally use the native Browser.
Some heavy/poorly supported sites can hang the browser process, so it doesn’t close properly when normally closed, you can try to ‘killall sailfish-browser’ and ‘killall booster-browser’ in terminal to get it to start again, then quickly close the problematic tab before it causes another hang again (you can ‘ps aux | grep browser’ to see all browser processes and hunt them down and kill them individually (there’ll be some firejail/invoker processes left over) by pid if the two killalls don’t fix it, but worked last time for me)
From a fresh reboot, try Settings app > Apps > Browser > Settings
From there select Start in private browsing mode
If that doesn’t help, you could try Clear browsing data
As the browser shares the Firefox engine, you could try manually deleting the data. Adapting this guide
/home/defaultuser/.local/share/org.sailfishos/browser/.mozilla/cache2 appears to host the cache files
and
/home/defaultuser/.local/share/org.sailfishos/browser/.mozilla are where the sqlite files are located
Please take care to backup the .mozilla directory before you attempt this and as always be very careful if you use the rm -rf command, you don’t need root privileges in this case, but you can still do a lot of damage. It might be better to use File Browser or FileCase if you’re not comfortable around the command line. (As .local/ is a hidden directory, you might need to enable ‘View hidden files’ from the file browser settings)
OT: The .mozilla/key4.db and .mozilla/logins.json can be transferred from one device to the next to restore your browser passwords. For some reason, my backup restoration failed in this regard,
Thnx for all your suggestions. The first thing I tried was to restart the phone. That did the job already
. The reason why I also thought the issue was more problematic was that the browser (in private & normal mode) shows 4 shortcuts: to the ‘Jolla site’, the ‘Jolla shop’, ‘Support’ and finally to ‘Community’. Having chosen ‘Community’, it reads at the top: ‘Your browser will soon be incompatible with this community. To keep participating here, please upgrade your browser or learn more.’
Never trust the internet ![]()
Aspecially that dumb useless thing called User agent.
I see also native browser very often frozen on my JP since beginning with 5.2.0.20. Now I am on 5.2.0.22.
Mostly it is by playing some videos. In this case I see frozen picture but hear still running audio. RAM consuption increases a lot.
Browser is in general very slow with rendering of websites compared with ddg or chromium running on AAS.
I haven’t any log or more special data, but this kind of issues I see every day. Mostly I need to change to AAS to browse websites.
Because there is no detail let*s me guess: So the browser is working and the issue lives in the video player?
Lol, so clear, that this kind of answer will come. ![]()
Lets just do so, as all other in the world have issue, but not the official sfos app ![]()
Edit: btw… Not one other browser have any issues on that pages. ![]()
