Jolla Phone update - Lights on, technical bits and the schedule
Yeap, the channel that @ljo refers has also rights to redistribute – Jolla - @fps_gbg – PeerTube
Order number is not a separate pre-order sequential number. If you’re in Batch 3 you’re in Batch 3, which is the first 10000.
Thank you for answer my question! Now it’s clear to me.
Hi there, i’m in batch 3 and i want to buy a custom made walletcase. Is there a technical drawing with dimensions that i can hand to the company that will make the case?
I would love to have the case before my jolla arrives :slight_smile:
withe regards,
Marcel
I am waiting on batch 3 , really anxious . Hope in the future for desktop feature to turn into mini Linux pc, better cam and best browser …
Hello, I’m writing this to the Jolla Tech team.
My new Jolla arrived today, thanks very much and I’m very excited. I started it up and got through most of the initial setup stuff. I didn’t put any SIM in and when it reached the internet connection page the connect button stayed inactive, so I eventually skipped and went through to the home page. It was reassuringly similar to my old Jolla phone from 2014 ( which still mostly works ). I then went to ‘settings’ and into ‘WLAN’. When I tried to switch the WLAN on it came up with the error message ‘WLAN adapter unavailable’, I think that was verbatim. I switched off and restarted several times with the same result. After about 5-6 times however, it now starts up and presents me with the ‘enter security code’ screen, as usual, but when I put in the code it gets stuck with the whirling circle. I shut down and tried several times with same result now. I’ve tried entering an incorrect security code and it quite properly tells me it’s incorrect and to reenter a code. When I then enter the correct code it does the whirling circle thing again. I’ve left it for half hour and screen stays awake, with all the ‘Enter security code’ detail and the whirling circle. I’ve not yet unscrewed the battery pack to remove power because I want to let you know I’m having problems before I interfere with the hardware.
What should I do ?
You should not try to write to Jolla team (quite busy ;), but just search this forum or ask directly.
There are quite a few instances of this kind of question in this forum and solution is there.
E.g.:
Hello guys,
finally herr, it has arrived. Inari Blue and I3C board
really happy about whatsapp, was the major concern but its wonderful so far .
i did not install any of the android related apps and it is little hard for now but, i intend to use it as daily driver if i can , only sailfish OS witch is the major reason for getting the phone and supporting Jolla to become the NOKIA we use to love . Until now, grat phone great job Jolla and i will be supporting as much as i can Jolla to be better and compete with the big brands in the future I hope EU Commision will support Jolla to become Europe nr 1 smartphone producer and also independent from US as we have become vulnerable and i thank president Trump for making us belive again in EU and not remain dependent of US products ! but EU remain united more than ever!
8 posts were split to a new topic: Support from the EU Comission?
