REPRODUCIBILITY: always
OS VERSION: 5.2.0.16
HARDWARE: Jolla Phone 2026
UI LANGUAGE: English
REGRESSION: New
The flashlight on my Jolla Phone 2026 doesn’t seem to turn on at all, no matter if in the camera or from quick settings.
none
1. Slide quicksettings down and tap the flashlight quicktoggle. 2. Nothing happens or 1. Open camera 2. Try to take a picture with the flash set to ON
or:
- Open Camera
- Turn on Flash
- Take a picture
The flashlight should turn on.
The flashlight doesn’t turn on.
none
I looked into dmesg and even logcat, in my eyes, everything seems to indicate that it should work just fine, but the flashlight doesn’t even blink or anything.
dogbin - famyfostyb - logcat snippet of me turning off and on the flash through quicktoggle
Sounds like a hardware issue to me. Contact the Jolla Zendesk for support.
Test it with csd-tool, open terminal and type and press enter:
csd
Choose “Individual test” and then “Main camera and flash”
Just got the same issue. I connected wireless headphones but sound was still coming from the speaker, I went to the bt settings to reconnect, but when reconnecting bluetooth just turned off and stoped turning back on again. I restarted my phone, bluetooth started working again, but now my flashlight is not working. I have no idea if those 2 thing are related. Did you maybe have the same thing?
I am also on Jolla Phone 2026 and 5.2.0.16 os version
Using csd tool there is still no flashlight
After a night charge flashlight seems to be working again, very strange
It seems that the flashlight gets disabled below a certain battery level, I believe either 15% or 20% is the cutoff. If it reaches below that point, the flashlight switches off and can’t be turned on until charged above the cutoff percentage. I’ve read it somewhere on the forums here.
So my advice is if anyone sees this same issue, try charging until at least 35% and retry.
Hmm, I will test it out, but I dont think it is consistant
