I tried that too, unfortunately without any change.
Here’s the result of zypper verify --dry-run and zypper verify
/ # zypper verify --dry-run
Building repository 'adaptation-common' cache ........................................................................................................................................................................................[done]
Error building the cache:
[adaptation0|plugin:ssu?repo=adaptation0] Valid metadata not found at specified URL
History:
- [|] Error trying to read from 'plugin:ssu?repo=adaptation0'
- Store credentials not received. Not connected to D-Bus server
Warning: Skipping repository 'adaptation0' because of the above error.
[aliendalvik|plugin:ssu?repo=aliendalvik] Valid metadata not found at specified URL
History:
- [|] Error trying to read from 'plugin:ssu?repo=aliendalvik'
Warning: Skipping repository 'aliendalvik' because of the above error.
Building repository 'apps' cache .....................................................................................................................................................................................................[done]
Building repository 'customer-jolla' cache ...........................................................................................................................................................................................[done]
Building repository 'hotfixes' cache .................................................................................................................................................................................................[done]
Building repository 'jolla' cache ....................................................................................................................................................................................................[done]
[sailfish-eas|plugin:ssu?repo=sailfish-eas] Valid metadata not found at specified URL
History:
- [|] Error trying to read from 'plugin:ssu?repo=sailfish-eas'
Warning: Skipping repository 'sailfish-eas' because of the above error.
[xt9|plugin:ssu?repo=xt9] Valid metadata not found at specified URL
History:
- [|] Error trying to read from 'plugin:ssu?repo=xt9'
Warning: Skipping repository 'xt9' because of the above error.
Some of the repositories have not been refreshed because of an error.
Loading repository data...
Reading installed packages...
Problem: product:# This file is copied as hw-release-1.0.0.8.analogous to os-release is not installable
Solution 1: deinstallation of product:# This file is copied as hw-release-1.0.0.8.analogous to os-release
Choose the above solution using '1' or cancel using 'c' [1/c/d/?] (c): 1
Resolving dependencies...
The following 2 products are going to be REMOVED:
No additional space will be used or freed after the operation.
Dependencies of all installed packages are satisfied.
/ # zypper verify
History:
History:
History:
History:
Aug 04 09:20:16 localhost kernel: **********************************************************
Aug 04 09:20:16 localhost kernel: ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
Aug 04 09:20:16 localhost kernel: ** **
Aug 04 09:20:16 localhost kernel: ** trace_printk() being used. Allocating extra memory. **
Aug 04 09:20:16 localhost kernel: ** This means that this is a DEBUG kernel and it is **
Aug 04 09:20:16 localhost kernel: ** unsafe for production use. **
Aug 04 09:20:16 localhost kernel: ** If you see this message and you are not debugging **
Aug 04 09:20:16 localhost kernel: ** the kernel, report this immediately to your vendor! **
Someone has left debug code in the kernel or kernel module, so nothing dangerous, mostly just a minor performance penalty because of the extra memory it takes.
My JP26 was stuck in a bootloop, meaning I only saw the Jolla logo but never the Sailfish logo that appears during boot. I also couldn’t get to the welcome screen where I could select the language or launch any apps.
If you plug in different chargers, do you see that it’s charging?
By “reset,” do you mean a factory reset, meaning resetting all data (be aware that all pictures, contacts, etc., will be deleted from the phone during a factory reset)?
So far, I only know of my own and your case where a bootloop occurred.
I’ve never established a USB connection with the JP26 using Windows 11.
You mentioned trying it with Linux Zorin OS.
Once you’ve opened a terminal in Zorin OS, monitor the output of dmesg using sudo dmesg -wT (“w” stands for following and “T” stands for “human-readable timestamp.”) and connect the JP26 to the PC. If you don’t see any USB output, the JP26’s USB port might be faulty or dirty or there could be some other issue with the connection between the JP26 and the PC.
Regardless of the state my JP26 was in, I always saw some USB connection information when connected to a Linux system.
To access the JP26 via telnet on my Arch Linux system, I first had to add the IP address 10.42.66.67 to the USB connection using sudo ip addr add 10.42.66.67/8 dev enp0s20f0u10. The device name (dev) will likely be different on your system. You can also see this with a “sudo dmesg” command.
With a USB connection to an Xperia 10 III, it looks like this:
[600324.761715] usb 1-10: Product: Xperia 10 III
[600324.761718] usb 1-10: Manufacturer: Sony
[600324.761720] usb 1-10: SerialNumber: X
[600324.832048] usbcore: registered new interface driver cdc_ether
[600324.836869] usbcore: registered new interface driver rndis_host
[600324.843562] rndis_host 1-10:1.0 enp0s20f0u10: renamed from usb0
where enp0s20f0u10 is the network interface.
Regarding your Question:
I sent a private message to @jolla not to any specific person.
Hi thank you for your good explanation. Will try again…
USB port should be ok on my JP26 because I see it in fastboot mode, but never in recovery mode. Tried yesterday an old ThinkPad laptop with LinuxLite…lsusb brings no port identifying Jolla. And that’s the same on Zorin, LinuxMint, Win11,10 and XP…
