Jolla Phone 2 detailed specifications
I’d like to create this thread as a fast overview of the JP2 specs, one can read out from having the device in hands as I think there is still no official detailed specification list available.
Jolla Phone (2026) 12GB/256GB 1st Batch (Day1 launch event)
Below are the readouts from AIDA64
System
Model: Jolla Phone
Hardware: mssi_64_64only_cn_armv8 2
Device: jp2601
Device Adaptation 1.0.0.10
Installed RAM: 12 GB
Total Memory: 11.3 GB
CPU
Core Architecture: 4x ARM Cortex-A55 @ 2000 MHz, 4x ARM Cortex-A78 @ 2400 MHz
Instruction Set: ARM64
CPU Revision: r1p0
CPU Cores: 8
CPU Clock Range: 650 - 2400 MHz
CPU ABI: arm64-v8a
AES: Supported
NEON: Not Supported
PMULL: Supported
SHA1: Supported
SHA2: Supported
Display
Screen Resolution: 1032 x 2272
Screen Size: 66 mm x 159 mm
Screen Diagonal: 6.78 inches
xdpi / ydpi: 397 /363
Divece Pixel Ratio: 1.00
GPU vendor: ARM
GPU Renderer: Mali-G610 MC2
GPU Version: OpenGL ES 3.2 v1.r54p1-…
Default Orientation: Primary
Battery
Technology: Li-ion
Voltage: ~4 V
Own measurements
Device
74.2 mm x 158 mm x 9.4mm (14.3 mm at the camera)
Screen
Dimensions: 61.9 mm x 149.9
Diagonal: 162 mm (6.38 inch)
Specifications from official Jolla store
SoC: Mediatek Dimensity 7100 5G platform
Memory: 8GB/128GB and 12GB/256GB memory configurations
Storage expandable up to 2TB with microSDXC memory card
Cellular: 4G + 5G with single tray two-sided dual nano-SIM with a separate slot for the microSDXC
Display: 6.36” ~390ppi FullHD AMOLED, aspect ratio 20:9, Gorilla Glass
Sony cameras: 50MP wide + 13MP ultrawide main cameras, front facing 32MP wide-lens selfie camera
Battery: 5450mAh, user replaceable
Connectivity: WiFi 6, BT 5.4, NFC
Dimensions: ~158 x 74 x 9mm, est. 190g
Other: Power key fingerprint reader, user changeable backcover, RGB indication LED, Privacy Switch
4G & 5G global roaming modem configuration:
LTE FDD: 1, 2, 3, 4, 5, 7, 8, 12, 17, 18, 19, 20, 25, 26, 28AB, 66
LTE TDD: 34, 38, 39, 40, 41
5G NR: n1, n2, n3, n5, n7, n8, n12, n20, n26, n28, n38, n40, n41, n66, n77, n78
If you have further information on the specifications gathered with other tools, please add them below.
PS: I don’t know why the screen dimensions are off in the AIDA64 readings. Could it be that there are outdated numbers stored in the system somewhere?
