The new Jolla 2026 works fine. But I have some (maybe small) problems:
The icon size is too small for my old (78 years) eyes.
Same problem I had with Jolla C2 but could be solved with this help: “dconf write /desktop/sailfish/silica/icon_size_louncher <parameter 151>”
parameter values
100 → 5 icons on one row
151 → 4 large icons
The above command has no effect in Jolla[2026].
Four icons in a row would be fine.
Sony wireless headphone WH-CH520 is not found with bluetooth of Jolla[2026]. My good old Jolla (xperia 10 III) detects all BT devices immediately. My LG HBS-FN6 earbuds connects without problems.
Are you sure you typed it correctly? And where these numbers come from? Are they in predetermined steps, or can the user enter any number and depending on the screen resolution, things will or won’t happen?
I simply copied the command as is. Not exactly the whole story because the text I have is only as picture (used screen copy with my iPad.)
Thank you @dumol, with 121 , i got back the feeling of my Xa2. So, to summerize, to get 4 larger icons rather than 5 smaller on my C2 screen i opened a terminal in devel-su mode and entered
dconf write /desktop/sailfish/silica/icon_size_launcher 121
And restarted my phone.
Not sure whether the unit of this number is in pixel or a % of the default size. I think with 100 you reset the display to 5 small default icons of the C2.
151 lead to 4 large icons filling almost completly the row and thus not beautiful.
121 was for me a good trade off.
Thanks you again
Thanks for exellent help. Installed Muoto Ui Themer and could find good combination.
Now I wonder why these helper apps are not listed somewhere in one place
Or am I the only one who has not found them.
