J2: Stuck with Bluetooth connect pop-up, unable to dismiss (no access to phone UI)
REPRODUCIBILITY: unknown
OS VERSION: 5.2.0.16
HARDWARE: Jolla Phone 2026
UI LANGUAGE: Slovenian
REGRESSION: unknown
One of my Aranet CO₂ sensors wanted to be re-paired (to AppSupport), and after I entered the pairing PIN, phone got stuck on the pairing popup – there was no way to do anything with the phone in this condition (locking and unlocking the screen just got me back to the pairing popup); I was able to answer a call with my bluetooth headset (I waited about half hour just to see if anything would time out). In the end I held the power button, which instead of showing the shutdown/reboot menu immediately started a shut down.
Also, not sure if this is related, but my Yealink BH71 bluetooth headset wouldn’t connect after powering the phone back on – I had to remove and re-pair it (tapping it in the Bluetooth settings gave a “Connection failed. Try to remove and re-add.” message almost immediately).
Unknown
  1. Unknown – no idea what triggered re-pairing of the sensor, and no idea why the popup got stuck
Device either pairs successfully, or pairing fails in reasonable time. Possibly also have some way to dismiss the popup (swipes from top and sides had no effect).
Phone unusable until reboot
AppSupport Bluetooth installed
Have you tried swiping from the right edge to the left or vice versa?
I definitely tried swiping from right edge to the left; I can’t remember if I tried the other direction, but I probably did. I also tried swiping from top down (both in the middle and at corners), and from bottom up.
OK. Pity, this worked for me in similar situations when it seemed there was no other way out.
