In Android settings* in “Security and privacy” there is “Settings > Device unlock”. When I go through the flow of setting it to anything I end up with “None” and pop up with: “Screen lock was already changed. Try again with the new screen lock”.
I need to this because “Okta Verify” app “requires screen lock confirmation to be enabled for your account.” Unless I am misunderstanding what it means.
*the one you access by going to settings “Android tm AppSupport” and clicking “android version” a few times
I have seen a patch in open repos, that is supposed to address exactly that. Lets you set screen lock in AAS so apps don’t complain.
Its called Appsupport lockscreen support, by nick8325. You can find it o Storeman and you will need patchmanager for that if you aren’t using any patches.
And three years old. In knowledging that a lot of devices ships out at the moment and with that maybe new users its ok that they dont do that much reseach…
