how do i do that in 4.4 SFOS
or is it broken
it used to work with the previous version
Works fine for me, and you shouldn’t have to do anything special.
I did need to go to storage in settings and mount it… maybe there was automounting before? I don’t recall.
it used to work fine fore me too… before
now it does not anymore
i used to go through stage in settings (i do not remember if automount worked
but klknow i do not see the stick at all
does anybody has an answer to this question
is my device at fault or is it a known bug
would somebody from the jolla team be kind enough to answer
XA2 4.4.0.64
OTG Works for me too
