How to set snooze duration?
Can somebody please help me find the setting where I can set the snooze duration (default seems to be 5 minutes) of the alarm? Thanks!
Edit: The tldr solution is Settings > Apps > Clock.
See Clock | Sailfish OS Documentation
You can find the settings for this by going to Settings, then to Display; there, among other options, you can select a time duration under “Turn off display after…”.
