How to install SailfishOS on Sony Xperia 10 IV
Hey
I just got an Sony Xperia 10 IV.
How do i install SailfishOS on this? can anyone guide?
Start from here.
But there exists no sailfish x Download For the xperia 10 iv !
what do you mean with “there exists no sailfish x Download […]”?
If i Click on the link on website it Leads to jolla Shop, but there is no Download For This xperia Version . >>> Or is there another Location? If yes, where do i find it?
If you want a free trial version, open this link: Jolla shop
If you want a full version, open this one: Jolla shop
In both case, you need an account
Yes, i Know These links and i also have an Account, but Try yourself: Download for the version xperia 10 iv is missing - altough it is described as „Supported“ in the respective jolla List …
This is how my choice of Downloads shows and clicking upon Xperia 10IV elicits Sailfish_OS-Jolla-5.0.0.72-xqcc54-1.0.0.52.zip
for me now works too, but before i had to “buy” a free trial (with purchase before it wasn’t there …) –> do i now have a lasting licence with android appsupport? or do i convert a trial to full version?
This is a trial-version which includes AAS at least for now.
I have purchased a License and i am facing same problem. I can not find the download for Sony Xperia IV XQ-CC54 ? Anyone can help
Can’t say for sure, but at least my understanding is that there isn’t currently license for 10 IV or V sold. They are still in “beta” phase and my understanding is you get AAS and everything you would get with purchased license with the free trial for 10 IV and V
I think CLMA31 is right on the money:
You probably need to get (“buy”) a Trial license:
If you have actually spent money then you have mistakenly purchased the legacy licence and need to request a refund because it does nothing for the 10 IV/V.
Anyway, I don’t remember the full process, but you should try getting the trial licence which should unlock the other options.
Standard disclaimer: it is a beta version and some important features don’t work correctly, but you probably knew that already if you know about the 10 IV port’s existence in the first place
I choose this phone model because it supports esim.
Where do i get a trial version any idea?
The Software doesnt support esim. And Jolla said, its on the roadmap but with low priority. So I would assume its not for 2026. One hint they are not working on it could be, that the J2 will have two sim-slots.
And if you didn’t notice that esim wont work, you probably should carefully read in the form about all the things that are not yet working on 10IV/V…
Here you go: Jolla shop
Which download is correct for the Sony Xperia 10 IV? I’ve paid €24.90 for the subscription and €4.72 for a “donation,” but I still can’t figure out where to download the actual software to begin installation. The process really needs to be simpler and more user-friendly.
I don’t get why eSIM isn’t a priority for this team. They claim to have built a secure product, yet users are stuck using physical SIM cards. At the same time, eSIMs are easy to get and don’t usually require KYC. It’s strange.
In my case at the and of the list there is the image for the 10IV - for you not?
I cant see
