Sony Xperia 10 II Binaries
Hello,
It’s my first time trying to run anything else than android on a Phone.
I bought a Sony Xperia 10 II with Android 12 on it.
I bought the Sailfish OS software from the website and followed the instructions. (I hope I did them the right way).
Then Step 5: Get the Sony software binaries.
I need: SW\_binaries\_for\_Xperia\_Android\_10.0.7.1\_r1\_v12b\_seine.zip
But there seems to be no way to get the right binaries.
I tried many things and looked online. But I don’t find a way to get the actual file.
Every time I try to download it on the Sony website, the file is corrupted.
Maybe someone got the file and can send it to me.
Or else I don’t think this phone will ever get Sailfish OS🥺
When you say corrupted, you mean you can’t unzip it?
Yes, the file is about 260kb small.
And if I try to unzip it, it says no no no no
It’s not clear from your post but have you followed the instructions in flashing-README.txt in the SFOS zip archive?
And you’re downloading from here?
Umm, I don’t think so. What step is that in the Installation guide?
Yeah, I looked again. It’s on there.
It originally says 102 mb, once downloaded it’s 0,26 kb.
So there’s something wrong with the file
Don’t give up. It is possible. I downloaded just a few weeks ago.
I mentioned a month ago that the download link by Sony is broken, and it seems they still haven’t fixed it. For some reason the file doesn’t exist after they moved things, the older version does work mostly you just cant take pictures with it (it freezes when you try to take a pic)
lou
13 June 2026 20:26
11
This exact version? Do you still have the file?
lou
13 June 2026 20:29
12
Okay, I will try a older version tomorrow. Thanks for the help🙏🏼
lou
14 June 2026 22:33
13
Hey, I tried with an older version.
It tells me the file isn’t in the directory, but it is.
Maybe I did some step wrong, but I’m not sure.
Hello,
I have the file, I will upload it tonight.
attah
15 June 2026 17:52
15
Fixed the logic for you - hope it makes sense now.
lou
16 June 2026 15:40
16
Hey, thats great news.
I hope it will work with that file eventually.
Hi,
here it is : Proton Drive
lou
16 June 2026 18:50
18
Everyone, thank you so much for the help.
I can try Sailfish OS now.
thanks I can also reinstall my phone.
also keep it safe, its possible that others might need it at least if Sony wont fix the download link
