Focus of textarea goes shortly away and comes back
I have following in the footer of a SilicaListview. When pushing the send button, keyboard goes very shortly away, and then comes back and gives focus again to the Textarea.
Is there a possibility to avoid that focus shortly goes away, and that keyboard just stays open and focus is kept to the textarea?
            footer :         Column {
                width: parent.width
                Item {
                    width: parent.width
                    height: replyField.height
                    TextArea {
                        width: parent.width - attachButton.width - sendButton.width - 2 * Theme.paddingSmall - Theme.horizontalPageMargin
                        //: Label for message
                        //% "Message"
                        label: qsTrId("message-la-message")
                        //: Placeholder for send message
                        //% "Send message"
                        placeholderText: qsTrId("message-ph-sendmessage")
                        hideLabelOnEmptyField: false
                        backgroundStyle: TextEditor.FilledBackground
                        horizontalAlignment: TextInput.AlignLeft
    //                    height: Math.min(implicitHeight, Theme.itemSizeExtraLarge * 2)
                        Component.onCompleted: {
                            page.replyFieldRef = replyField
                            replyField.text = Drafts.loadDraft(roomId)
                    Row {
                        anchors.right: parent.right
                        anchors.bottom: parent.bottom
                        spacing: Theme.paddingSmall
                        Button {
                            width: Theme.iconSizeMedium + 2 * Theme.paddingSmall
                            height: width
                            icon.source: "image://theme/icon-m-attach"
                            onClicked:
                                pageStack.animatorPush(Qt.resolvedUrl("ImageSelectPage.qml"))
                        Button {
                            height: width
                            icon.source: "image://theme/icon-m-send"
                            onClicked: {
                                if (replyField.text !== "") {
                                    //: Notification when sending message
                                    //% "Sending message"
                                    Notices.show(qsTrId("message-no-messagesending"), Notice.Short, Notice.Center)
                                    console.log("fake send, no backend call")
                                    matrixSession.sendTextMessage(roomId, replyField.text)
                                    replyField.forceActiveFocus()
Well, once you click sendButton, it gets focus, the textarea loses focus ergo the VKB goes away. Then you call forceActiveFocus and it appears again.
To quote a great movie:
I am drowning and you are describing the water.
I have no immediate solution, except you could trigger the sending using EnterKey.onClicked from the VKB - but usually that’s not what you want in text messages.
Maybe if you move the send button into rightItem that issue goes away but I haven’t tested that.
Great, the rightItem suggestion works. Thanks a lot!
Real champ! Thank you Nephros for being so valuable member of the community❤
