Fahrplan thread
No, I haven’t gotten to 9292 yet. I’ll try in the next week.
Hi, quick question: how do you delete favourite stations in Fahrplan? I can’t figure out how this works
It should just be, search for departure/arrival
select the fave at the bottom of the page before searching and
‘remove from favourites’
Ah thanks. I tried that before but apperntly, because I wanted to delete the last item in the list, the menu glitched out-of-screen. Now I played with it a bit and could delete it
Hi, I have yet another question. If Fahrplan shows less trains than the official app from the rail service for the same route, is this an error with Fahrplan or is it likely that the API just doesn’t provide these trains?
It’s probable that the API doesn’t cover everything. If you can give me an example, I can take a look. In any case, there are limits to the API.
I’m using the Austrian oebb.at API.
Here is an example:
When I search for a train from Salzburg to Linz, Fahrplan cannot see the trains operated by the private „Westbahn“-company (the WB-trains), while the official „ÖBB Scotty“ app can see those trains just fine, even though they are from a different operator.
Ah, thanks for the heads up. The oebb.at api ‘should’ cover everything the ÖBB does. That seems like a settings thing. I’ll have a look next week …
Is it just me or are others also experiencing problems with the bahn.de backend today? It worked fine just yesterday. Hope they haven’t changed the api…
yes i get cannot parse reply from server
Same for me. Can switch to oebb.at as workaround until fix is there
Same here, bahn.de source stopped working :disappointed_face:
Yes something must have changed with the Journey API Endpoint. Location and Timetable API Endpoints still work but the Journey API Endpoint now always returns a 405 Method not allowed error. There seems to be a new Domain for the API but sadly changing to that one does not fix the problem.
Update: Found the cause. The Journey API Endpoint Version was updated from v8 to v9.
@poetaster Haven’t tested it yet but should be It’s enough to change v8 to v9 in the mime type parameter in the sendHttpRequestMovas call (last line of ParserMovasBahnDe::internalSearchJourney).
I’ll try this later today. Have to do some driving first :slight_smile:
EDIT: @kfg I’ve posted the fixes and made a release …
2.0.49 is now available on openrepos and coming to chum … Thanks @kfg!
Thanks! Works again.
Thank you so much!
Berlin without Fahrplan is a mess.
