How can SimPro be installed om jolla phone 2026?
Downloading it from OpemRepos and then trying to install gives an error
Is the software Android app com.simpro.mobile version 17.6.0
You could download it directly from the OpenRepos page and try installing it with pkcon.
Perhaps this will show a more descriptive error message:
devel-su pkcon install-local harbour-simpro-0.8-1.noarch.rpm
Going to try that tomorrow or latest this sunday. Will feedback here.
Tried to install the harbour-simpro.
Becuase of the fatal error tried to install the lpac
Because of the fatal error tried to install the provided pcsc-lite
Because of the fatal error tried to install the provided pcsc-ccid
And that also gives a fatal error.
Seems to me some (linux) libraries are missing on Jolla Phone 2026.
$ devel-su pkcon install-local harbour-simpro-0.8-1.noarch.rpm
Password:
Installing files
Testing changes
Finished
Fatal error: nothing provides âlpac >= 2.3.0.2â needed by the to be installed harbour-simpro-0.8-1.noarch
$ devel-su pkcon install-local lpac-2.3.0.2-2.aarch64.rpm
Password:
Installing files
Testing changes
Finished
Fatal error: nothing provides âlibpcsclite.so.1()(64bit)â needed by the to be installed lpac-2.3.0.2-2.aarch64
$ devel-su pkcon install-local pcsc-lite-1.8.10-1.1.1.bso_.aarch64_0.rpm
Password:
Installing files
Testing changes
Finished
Fatal error: nothing provides âlibpcsclite1 = 1.8.10â needed by the to be installed pcsc-lite-1.8.10-1.1.1.bso.aarch64
$ devel-su pkcon install-local pcsc-ccid-1.4.35-1.2.1.bso_.aarch64_0.rpm
Password:
Installing files
Testing changes
Finished
Fatal error: nothing provides âpcsc-lite >= 1.6.6â needed by the to be installed pcsc-ccid-1.4.35-1.2.1.bso.aarch64
For pcsc libraries you need chum repo added. For lpac, you need chum repo or juanro49 openrepos repo added. Add them before install SimPro
If youâre okay with that I could additionally bundle the RPMs into the SimPro repo so issues like that donât happen any more.
Why not build SimPro on chum too?
And have it installable from the Jolla Store ?
Personally I not mind playing around with command lines, but for mainstream adoption it should be âclick and installâ
Thatâs a good option; another is to add the instructions for adding those repos to the spec file, or even to add SimPro to chum How to add an app to Chum?
Ok, managed to download Chum GUI installer. After that install lpac, and SimPro.
Unfortunately SimPro is somehow not able to read my 9eSim via the 9eSim cardreader in the USB-c. The 9eSim combination does work in my realme C85 5G
As the led on the cardreader is intermittent on/off when connected to the Jolla (it is continuously on on the realme), I suspect some power issue. Anywhere I can find info in a log e.g. ?
Interesting. In my case itâs the opposite. Management doesnât work through the SIM-card slot, but no issues with external 9esim cardreader on Jolla Phone 2026
I did not even try the simcard slot, as it does not support eSim (afaik). One difference might be : I donât have any sim in the phone yet. I already noticed that GPS canât fix without sim inserted. Maybe the external adapter also cannot work without sim inserted in one of the slots
Saatana I broke my nail ejecting SIM xD
USB adapter works fine on my phone when no SIM inserted inside
Sorry for your nailâŚ
Now I have tried again. Seems if I open the menu, then insert the adapter, and quickly click SimPro to start, it now also runs on my phone.
This way to start SimPro I did not try before.
Starting SimPro and only then insert the adapter wonât work. SimPro will not refresh(?) or show the adapter with the eSim.
So now I know how to get SimPro to see the adapter.
What phone? Works in both my Xperia 10 II and III.
Jolla Phone 2 (2026). It has no eSim support on the builtin sim slots.
You can with a physical esim adapter.
As documented above in this thread you can either use lpac (using the command line) from Chum or the app SimPro by @cypherpunks to manage the loading/selection of esims with the adapter
The first success of lpac working on Sailfish is here, with a 9esim card, keep reading for other examples of adapters that have worked here
