Emergency call button not responding from lock screen – Jolla Phone 2026 / Sailfish OS 5.2.0.22
OS VERSION: Sailfish OS 5.2.0.22
HARDWARE: Jolla Phone (2026)
UI LANGUAGE:Finnish
Severity: Critical – Safety-related issue
I encountered a potentially critical safety issue when attempting to initiate an emergency call from the lock screen.
After selecting the emergency call option (red phone icon), the device opened a screen titled “Hätäpuhelu” (Emergency Call), displaying a white “Soita” (Call) button.
However, tapping the white “Soita” button briefly did not initiate a call or produce any visible response.
I did not test whether a long press would activate the button.
The only way I found to proceed was to unlock the device, open the regular phone dialer, manually enter 112 and initiate the call from there.
When emergency call is tried to call from lock screen
  1. NOT RECOMMENDED BECAUSE REPRODUCING MIGHT ACTIVATE REAL EMERGENCY CALL
The emergency call function should respond reliably and allow an emergency call to be initiated without unlocking the device.
If a long press is required, this should be clearly indicated in the user interface.
- The emergency calling screen opened normally.
  • The white “Soita” button did not respond to a short tap.
  • No visible error message or feedback appeared.
  • I did not test a long press.
  • Accessing the regular dialer required unlocking the device.
Written with help of AI
After investigating this further, I would like to clarify my original report.
This may not actually be a functional bug, but rather a poorly designed emergency calling interface.
It appears that the user is expected to manually enter the emergency number (112) before pressing the “Soita” (Call) button.
However, the interface does not clearly indicate this requirement. The “Soita” button appears active even when no number has been entered, and pressing it provides no visible feedback.
This initially led me to believe that the emergency calling functionality was broken.
I would therefore classify this primarily as a usability issue with potential safety implications, rather than a confirmed functional bug.
In an emergency, the interface should be as intuitive and unambiguous as possible, especially when the user may be under significant stress.
A simple instruction such as “Enter emergency number” would already make the interface much clearer.
