Thank you for your kind words ![]()
Thank you CLMA31 for the nice post! Much appreciated ![]()
I can safely undersign the buzz and the heart-warming atmosphere (ambience?) at Jolla’s office! ![]()
Just that…noooo…this is torture… The wait will be toooooo loooooong to know what is coming.. ![]()
I will go a little bit off topic with this one, but I hope nobody minds….
So during the weekend I pulled the plug and transited over to the replacement Jolla phone. As some of you know, I don’t understand much from tech POV or have confidence of doing any hacks. So I immediately thought that, hey I’m simple man, let’s go simple route and install everything back like it was one-by-one. During this process I noticed different things and I use this space to summarize those….
SailfishOS internal backup. Amazing feature, but few things to note down. Just before changing SIM and SD card over, I made backup to Nextcloud and memory card with build-in tools. But when I tried to activate this backup with the new phone, it said that no backups in Nextcloud. I don’t know if this is known and recurring bug? But it didn’t bother me as I was able to restore from SD card! It would be nice if all accounts would immediately start working without needing to basically add everything again manually after restoring backup. But this is known bug and might be improved in the future. Already talked topic also is that it would be amazing if backup would restore all the settings the way they were on old phone. Small thing, but would be nice quality of life thing.
Then came the time to install all native apps back… It was pleasure to notice that I got like 90% of my native apps from Harbour!
With this transition I switched BitSailor from OR version to Harbour. I surely will miss fingerprint usage, but I’m wishful to have that one day even with Harbour build ( Fingerprint framework for developers ). How cool would it be if backup also included all the apps and their credentials in the backup? I would love that
Luckily phone migration isn’t every day shore…
Then I started to install stuff from Chum. From there everything I needed was Ferry Sync (Cloud File Sync) , Bugger! - the most widely used inofficial SFOS Bug Reporting Tool , Stumblefish: a BeaconDB stumbler for Sailfish OS & Foilauth — SailfishOS:Chum, a Sailfish OS software repository by the community . I “downgraded” Pure Maps (Native map app) to the Harbour version also, at least for now. I would love to see update in Harbour for this at some point, but in case I need newer I will just transit to Chum one. With these I were almost finished… Then came the Whisperfish - The unofficial SailfishOS Signal client . Well OR is read-only for now and I still haven’t installed Storeman to my new phone (wanted to see if I could live without). As it was only one (super important app) and @rubdos + @direc85 have made superb work to have always rpm available at the GL repo I just installed from there. Aaaand I was ready from native app POV
Not a single app from OR/Storeman for now. (I need to also install either RawFish or ProCam from their repos soon™). The File Browser is a little bit too limited to my taste from Harbour so I probably need to get that from repo directly also, but super happy to also have the Harbour version!
Then came the boring semi mandatory android stuff I installed. I felt a little pain in my heart while installing these, but there was nothing major here as I have now done these apps three times in a year. BitSailor is true MVP here while setting everything up as I just copy-paste credentials to every app. My main bank app broke down recently Finnish OP-Mobiili , but the GOATs in Jolla are working hard to improve situation with future updates Community meeting on October 29, 2026 - #24 by rainemak
This one will be nice Christmas present for sure.
Ah, almost forgot… In the first setup process, something went wrong and anything related to AAS couldn’t install. But I was able to install everything from Harbour myself so not a big hurdle.
For this, I would say I spend ~8h to have everything the same way. It is long time, but to be fair I don’t plan to transit away anytime soon so for one-time job not so bad. There definitely would still be room for quality of life improvements in the backup, but generally I’m happy. Browser didn’t have anymore my saved credentials (no biggies as there is BitSailor). Hopefully one day those could be imported from Firefox along side with bookmarks.
Again, wall of text, thank you and sorry if you read all the way here ![]()
Re: browser password/logins missing after restoration of backup
copying /home/defaultuser/.local/share/org.sailfishos/browser/.mozilla/key4.db and logins.json from the old device to the new will restore them
Thanks for the hint! If the fix is so simple, I hope it will be fixed for all at one point! BTW is the backup functionality OSS already?
i don’t know if it’s open source. i’ll write a bug report, i wasn’t sure if others had experienced the same issue
Thank you for your help, highly appreciated!
It’s (probably) coming, even before some universal fingerprint framework.
Whaat, that is amazing!![]()
I had the same issue when switching from Dusty Jolla to the Awesome Clear Selfies Jolla (namings are mine, no trademark or patent pending
). What I had to do was
- Create a backup in the new phone to Nextcloud
- Open the Nextcloud backup folder in my PC
- Rename the old backup with as the new backup (copy paste new backup file name to the old one)
- Can’t remember anymore if I had to rename the folder also, as the new phone created a new subfolder under the backup folder (sorry, didn’t document the process)
- Restore backup
So, it’s more of a plug-and-pray kind of situation with the Nextcloud backup. And if might startle some users when they see “No backups” text in the settings.
Yeah, hopefully that will be improved at some point. Does someone know if the Nextcloud integration is open sourced yet?
