but because of the original plastic protectic cover I bought
with it there is a problem with the cut out openings in the cover,
since the cuttings are too inaccurate so for several functions to work I need to
remove the plastic rubberish cover to make the usb-cord to fit and reach the bottom of
the connector, so all functions will actually work. Maybe you should include a proper cover or proper cover + charger included in the first place PS. I live in Finland , EU.
The C2 is an interesting beast.
It is not designed and made by Jolla like the J2, but it is an off the shelf phone from a Turkish manufacturer, Reeder. The same hardware can be bought with Android as Reeder S19 Max Pro S. (the name itself is a seal of quality…)
Anyway, all the accessories that can be bought for the C2 are made for the original, Android version by Reeder, or rather, some kind of very cheap Chinese OEM, thus Jolla has no control over the quality.
The C2 device dimensions and the lens and key positions are almost exactly the same as the ones of the Samsung A05s. I bought a cover and with minor extra cuts it fits quite well. Availability is much, much better than the Reeder covers, at least in the European Union.
