Complete crash when charging
Chargers are very much software dependent for a decade. There seems to be an issue with power negotiations.
Felis says always discharging.
I forgot to mention that when the charger (PD) stopped charging the phone, it caused the phone to crash. This happened to me twice. To restart the phone, I had to press and hold the power button (for 10–15 seconds).
@mal, reporting after a week of testing.
  • The option to keep the display on during charging is buggy, sometimes the display still turns off. I didn’t find any real pattern, other than that if you turn on the screen explicitly after it turns of it mostly seems to stay on.
  • When the display stayed on, I did not observe any freeze
  • When the display did turn off, I observed two freezes. I think one happened quite soon after starting charging. In that particular instance the phone screen was off, then I plugged in the charger and the screen turned on. Soon after (minutes) I noticed the screen was turned off again and the charging led not animating anymore.
  • Total cycles ~7, not sure if this is a significant number.
How did the battery charge level behave when you were charging with display on? Did it increase correctly or not?
No difference compared to display off, i.e. updated correctly when it didn’t crash, and when it did crash the indicator was again wrong.
@filip.k, I just noticed you merged this topic into this one, but reading that other one I don’t think they are the same. The other topic seem to be about inability to charge at all, while this one is about the phone crashing but it does continue to charge.
Yeah, nowadays the robust and fast PD charging is really complex. Maybe I was too fast to merge them.
What do you suggest?
I’d suggest keep them separate for now, at the moment to me at least he other topic reads like it could even be a hw issue (loose connection), and otherwise a different software issue. The reporter should post some logs from around the time they are inserting the cable, that might help distinguish.
For now I reopened that bug report. I do hope for a quick solution of both.
I’m back from holidays.But the issue still remains. Yesterday I tested with felis on wired connection to laptop and directly to power supply. The status in felis is always discharging. After plugin the cable there is no status change. From jolla I don’t get any feedback from support (via zendesk or e-mail to shop).
Any help?
