Cellular/4G down after voice call (Xperia X / SFOS 3.3.0.16)
REPRODUCIBILITY: 100%
BUILD ID: 3.3.0.16
HARDWARE: Xperia X
UI LANGUAGE: DE
REGRESSION: Yes
I am not sure when it starts (before 3.3 or 3.2) but every time after doing a voice call over cellular after finishing the call, the cellular stack went down (the icons in the top right corner for “data”, Gtype (4G) and signal are gone (signal icon are striped indicating not connected at all)).
Provider: Vodafone DE
only confirmed on Xperia 10 (the only device here)
  1. Do a call
  2. Finish the call
  3. Try a second call right away.
Doing a second call right away without waiting for the software stack being ready.
I must wait until the cellular network is connected again to do a second call.
Here some journal logs while this happend:
Aug 17 12:44:56 Sailfish invoker[20648]: WARNING: An inactive plugin is misbehaving - tried to show a window!
Aug 17 12:44:56 Sailfish invoker[20648]: WARNING: requestActivate() called for  QQuickView(0xa78390)  which has Qt::WindowDoesNotAcceptFocus set.
Aug 17 12:44:57 Sailfish [4990]: [W] unknown:0 - void TelepathyProvider::onHandlerInvalidated(const QString&, const QString&) Handler invalidated: org.freedesktop.Telepathy.Error.Terminated: Release By User
Aug 17 12:44:57 Sailfish [4990]: [D] unknown:0 - "Telepathy Handler Invalidated: org.freedesktop.Telepathy.Error.Terminated - Release By User"
Aug 17 12:44:57 Sailfish tart[20665]: [W] updateAction:205 - instance was empty
Aug 17 12:44:57 Sailfish lipstick[20251]: [D] onDestruction:267 - coverActionIndicators destroyed voicecall-ui.desktop
Aug 17 12:44:57 Sailfish mce[2027]: tklock.c: tklock_dbus_notification_beg_cb(): notification begin from name=:1.1439 owner=:1.1439 pid=20251 uid=100000 gid=999 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevkeyboard:k
Aug 17 12:44:57 Sailfish mce[2027]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = none -> notif
Aug 17 12:44:57 Sailfish tart[20665]: [W] unknown:0 - InitManagerJob Error: Job was deleted before finished!
Aug 17 12:44:57 Sailfish lipstick[20251]: [D] onCompleted:263 - coverActionIndicators created voicecall-ui.desktop
Aug 17 12:44:59 Sailfish rmt_storage:INFO:rmt_storage_rw_iovec_cb: Write iovec request received for /boot/modem_fs1
Aug 17 12:44:59 Sailfish rmt_storage:INFO:rmt_storage_client_thread: Calling Write [offset=0, size=2097152]for /boot/modem_fs1!
Aug 17 12:44:59 Sailfish rmt_storage:INFO:rmt_storage_client_thread: Done Write (bytes = 2097152) for /boot/modem_fs1!
Aug 17 12:45:03 Sailfish mce[2027]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = notif -> none
Aug 17 12:45:08 Sailfish mce[2027]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> UNDEF
Aug 17 12:45:15 Sailfish connmand[4635]: [ofono] ERROR! Timeout was reached
Aug 17 12:45:16 Sailfish ofonod[2968]: data reg changed 1 -> 0 (unregistered), attached 0
Aug 17 12:45:17 Sailfish droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
Aug 17 12:45:17 Sailfish kernel: R0: [netmgrd][29517720201543] [12:45:17.581545]  wlan: [3824:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:17 Sailfish mce[2027]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = none -> notif
Aug 17 12:45:17 Sailfish kernel: R0: [soft_irq][29517722406835] [12:45:17.696389]  wlan: [0:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:17 Sailfish ofonod[2968]: data reg changed 0 -> 1 (registered), attached 1
Aug 17 12:45:17 Sailfish kernel: R0: [ip][29517725587563] [12:45:17.862036]  wlan: [29846:E :HDD] __wlan_hdd_ipv4_changed: 926: Adapter context is invalid 0000000000000000
Aug 17 12:45:18 Sailfish kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 17 12:45:18 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:18 Sailfish ofonod[2968]: setting up data call
Aug 17 12:45:18 Sailfish mce[2027]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: UNDEF -> OPEN
Aug 17 12:45:18 Sailfish kernel: R0: [ip][29517730729801] [12:45:18.129844]  wlan: [29891:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:18 Sailfish kernel: R0: [soft_irq][29517730838655] [12:45:18.135513]  wlan: [0:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:18 Sailfish mce[2027]: tklock.c: tklock_dbus_notification_beg_cb(): notification begin from name=:1.1439 owner=:1.1439 pid=20251 uid=100000 gid=999 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevkeyboard:k
Aug 17 12:45:18 Sailfish ofonod[2968]: Deactivating context: 1
Aug 17 12:45:18 Sailfish ofonod[2968]: Clearing active context
Aug 17 12:45:18 Sailfish kernel: R0: [ofonod][29517737193235] [12:45:18.466460]  wlan: [2968:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:18 Sailfish kernel: R0: [ofonod][29517737194243] [12:45:18.466512]  wlan: [2968:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:18 Sailfish ofonod[2968]: Deactivated data call
Aug 17 12:45:18 Sailfish connmand[4635]: Failed to connect to server 2a01:0860:0000:0300:0000:0000:0000:0053
Aug 17 12:45:18 Sailfish connmand[4635]: Failed to connect to server 2a01:0860:0000:0300:0000:0000:0000:0153
Aug 17 12:45:18 Sailfish kernel: R0: [connmand][29517737780442] [12:45:18.497041]  wlan: [4635:E :HDD] __wlan_hdd_ipv4_changed: 926: Adapter context is invalid 0000000000000000
Aug 17 12:45:18 Sailfish connmand[4635]: Skipping disconnect of /ril_0, network is connecting.
Aug 17 12:45:18 Sailfish ofonod[2968]: Activating context: 1
Aug 17 12:45:18 Sailfish ofonod[2968]: Unexpected data call status 4106
Aug 17 12:45:18 Sailfish connmand[4635]: [ofono] ERROR! GDBus.Error:org.ofono.Error.Failed: Operation failed
Aug 17 12:45:19 Sailfish connmand[4635]: Skipping disconnect of /ril_0, network is connecting.
Aug 17 12:45:19 Sailfish ofonod[2968]: Activating context: 1
Aug 17 12:45:19 Sailfish kernel: R0: [ip][29517756953355] [12:45:19.495567]  wlan: [29927:E :HDD] __wlan_hdd_ipv4_changed: 926: Adapter context is invalid 0000000000000000
Aug 17 12:45:19 Sailfish kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Aug 17 12:45:19 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:19 Sailfish ofonod[2968]: setting up data call
Aug 17 12:45:19 Sailfish kernel: R0: [connmand][29517762395637] [12:45:19.779001]  wlan: [4635:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:19 Sailfish kernel: R0: [soft_irq][29517762480904] [12:45:19.783442]  wlan: [0:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:19 Sailfish kernel: R0: [ip][29517763048728] [12:45:19.813014]  wlan: [29936:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:19 Sailfish kernel: R0: [soft_irq][29517764466941] [12:45:19.886875]  wlan: [0:E :HDD] __wlan_hdd_ipv6_changed: 232: Adapter context is invalid 0000000000000000
Aug 17 12:45:20 Sailfish connmand[4635]: ntp: adjust (slew): +0.158213 sec
Aug 17 12:45:20 Sailfish kernel: ipa ipa_inc_acquire_wakelock:3494 client enum 1 mask already set. ref cnt = 6
Aug 17 12:45:21 Sailfish systemd[4830]: Unknown permission start for class system
Aug 17 12:45:21 Sailfish connmand[4635]: ntp: adjust (slew): +0.008941 sec
Aug 17 12:45:22 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:23 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:24 Sailfish mce[2027]: tklock.c: tklock_dbus_notification_beg_cb(): notification begin from name=:1.1439 owner=:1.1439 pid=20251 uid=100000 gid=999 priv=1 cmd=/usr/bin/lipstick -plugin evdevtouch -plugin evdevkeyboard:k
Aug 17 12:45:27 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:28 Sailfish healthd: battery l=69 v=3945 t=34.0 h=2 st=2 c=26 chg=u
Aug 17 12:45:28 Sailfish kernel: R0: [power@1.3-servi][29517922291302] [12:45:28.107780]  wlan: [3163:I :HDD] wlan_hdd_modules_are_enabled: 851: Modules not enabled, Present status: 3
Aug 17 12:45:28 Sailfish kernel: R0: [power@1.3-servi][29517922938366] [12:45:28.141483]  wlan: [3163:I :HDD] wlan_hdd_modules_are_enabled: 851: Modules not enabled, Present status: 3
Aug 17 12:45:29 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:30 Sailfish mce[2027]: tklock.c: tklock_datapipe_uiexception_type_cb(): uiexception_type = notif -> none
Aug 17 12:45:34 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:35 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:35 Sailfish mce[2027]: modules/proximity.c: mp_datapipe_set_proximity_sensor_actual(): state: OPEN -> UNDEF
Aug 17 12:45:48 Sailfish healthd: battery l=69 v=3978 t=34.0 h=2 st=2 c=-260 chg=u
Aug 17 12:45:50 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
Aug 17 12:45:51 Sailfish kernel: HTB: quantum of class 10010 is big. Consider r2q change.
