I was checking out the license for sailfishos. Under the country, only EU is available. Can I just select a random location and just purchase the software to use? Since it is just a software, it doesn’t matter right? I should be able to purchase it and flash it on my Xperia.
Yes you can.
I’d recommend trying out the Free version first to make sure, and later purchase a licensed version (and/or voluntary subscription).
IANAL, but the restrictions on EU are mainly for legal reasons - you likely have no warranty etc. claims against Jolla from elsewhere.
Note that 4G telephony (VoLTE) is a huge mess, and may or may not work in your country, with or without SFOS, with your network provider or others.
no worries. my sailfish phone is restrictly wifi only device. but thanks for letting me know.
