Camera not working on my Xperia 10V. Not sure if this is a bug
I can’t use my camera on my Xperia 10V.
The application loads, the buttons are visible,
but the camera image itself shows a black screen,
and I’m unable to press the shutter button, nor the record button.
All other buttons work.
If you search the forum, you will know that camera is one of those things that don’t work on not yet supported X10V.
My apologies.
I did not find a forum topic saying this specifically.
Apart from Android AppSupport, which has been released, and the battery status issues that have been fixed, most of the limitations mentioned in these release notes still apply.
Battery status has certainly not been fixed on my end.
According to this thread, using an Android 14 base with v4b Sony blobs should enable battery status to work correctly.
I have an Android 13 base. How do I get it up to 14?
It works for me on Android 13. Just update the blobs.
