Caldav Sync doesn't work on Jollaphone 2026 / 5.2.0.17
Although there have been some reported syncing-issues, they did not fit to my problem. Which is: I did not manage to sync my caldav-online-calender (zoho.eu), although it worked on the xperia XIII with SFOS 5.1.0.11 and I just copied all the settings and paths, rsp. I also tried it with fresh settings as indicated in the calendar website. The error-message reads (translated from German): “Couldn’t create an account. Check the login-information and retry. Authentication-error.”
I am not fully sure if it is an issue of the calendar-app in SFOS 5.2.0.17, or if it is an issue of the calendar-provider zoho … Any ideas or similar troubles? I also tried all sorts of login-information, and settings.
I’m also affected by this. I feel like I have tried everything.
Any chance you can provide the syncing logs? They could provide some clues
Indeed, and additionally, you may also try directly from the command line :
  • install buteo-sync-plugin-caldav-tools package (devel-su pkcon install buteo-sync-plugin-caldav-tools).
  • try to list your calendars with QT_LOGGING_RULES="*.debug=true" dav-client -u your.login@provider.org -P "xxxxxxx" -S caldav -D provider.org --list-calendars "".
dav-client can also work with a direct server URL and root, without relying on discovering features : dav-client -u your.login@provider.org -P "xxxxxxxxx" -s https://dav.provider.org -R path/to/dav/service --list-calendars ""
Change provider.org with the DNS name of your provider (like mailbox.org for instance), or https://dav.provider.org with the full server name hosting the DAV service. Use a -R option if the DAV service is not available at the root of your server.
