Busybox find misbehaves
REPRODUCIBILITY: 100%
OS VERSION: 4.6.x I forgot to check the busybox version before updating to 5.0.x, but I’m guessing it was 1.36.1 just as it is now
HARDWARE: 10 II (but this is not hardware-specific)
UI LANGUAGE: en_GB.utf8
REGRESSION: no
The busybox find applet has a bug that can result in data loss.
Use find on the command line
  1. find -name '*something*' => finds n results under the current directory
  2. find -name '*something*' -delete => deletes results that are elsewhere in the filesystem
Only files that were previously found with the same regex will be deleted.
Files that were not in the previous search result also get deleted
Does it happen if you specify the search start directory?
… because the path(s) (for the search base directory(ies)) is not an optional argument, see pubs.opengroup.org/onlinepubs/9699919799/utilities/find.html.
from busybox usage: Defaults: PATH is current directory
so, if find behaves differently from find . that is also a bug
PATH is optional on both GNU find and (more relevantly) busybox find
BusyBox v1.36.1 (2024-12-03 00:00:00 UTC) multi-call binary.
Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS]
find (GNU findutils) 4.10.0
Usage: find [-H] [-L] [-P] [-Olevel] [-D debugopts] [path...] [expression]
(edit: i’m not saying youre wrong, of course, in that POSIX find says its required…but as far as i know, only macosx peasants have to actually live with such a sadly impoverished shell)
that does sound like a bug to me, though probably not a sailfish bug. can you reproduce with busybox find on other systems?
or give a short script that reproduces?
I am wary trying to reproduce it on my phone.
I tried on my desktop (installed busybox, created a separate user, used busybox find) but could not recreate.
Over the years I learned to rely on using find this way:
  1. find what you want to delete first
  2. use the exact same command line with an added -delete
That not working as expected is a problem.
Of course I cannot complete rule out PEBKAC but the data loss was very real…
I will continue trying to reproduce this without the danger of bricking my phone.
sorry for your loss. you may wish to consider doing something like find -type f -exec echo rm '{}' \; | tee delete-script.sh for scary jobs
also, allow me to offer the worst advice to hear at this time; consider doing full, regular, fully-automated backups
Any advice on full backups of a sailfish device?
The build in Backup isn’t cutting it for me as I couldn’t restore them by just moving the newest one from the last device into the folder for my new device. Restore couldn’t find only the one I made to get the folder established on my share.
I also rummaged in the content to see, what I could restore manually and I didn’t find anything for android apps in there, which was quite the disappointment.
yea, i have advice, but it is somewhat idiosyncratic. my advice is to rsync your entire home dir overnight.
for my backup, i start with a full home rsync, which makes backup simple but restoring a nightmare.
i then take individual things i care about, like commhistory and ~/Pictures, etc, and back them up using more nuanced custom scripts, and then add --excludes to my home backup.
this is the repo where i keep my personal backup scripts. they are not likely to work in any given environment and are for my own weird use, but feel free to take a look and see if you can get them to work for you at your own risk :slight_smile:
https://github.com/teleshoes/sx-config/blob/master/backup-phone
BSD troglodytes similary have to endure the stone-age agony of their find program, forever chiseling away at their sanity with tools from the digital Paleolithic.
This is a bit offtopic…
You can use the search tool which will show you many results.
