[Solved] Botched up installation of Quartermaster
(This might be something for @BlacksheepGER …)
I was exoerimenting with Home Assistant yesterday and started off with a test installation on a test machine. I got that running and to round off the test, I also installed Quartermaster on my Xperia X (4.0.1 - on the one with 3.4.x, Quartermaster does not install, it seems). Got it connected just fine, everything working.
Later yesterday, I decided to set up Home Assistent “for real” on my server, so new installation on a different IP. Once that was running, I ditched the test installation and went on to try and reconfigure Quartermaster. To start with, Quartermaster just hung upon start (I waited minutes…). So, apparently, no direct way to reconfigure. I then proceeded to find and remove all quartermaster files in the home directory of “defaultuser” (including one in “privileged”), then removed and re-installed Quartermaster. No dice - upon start, Quartermaster still hangs. I repeated that process, this time also deleting a lock file somewhere in /run/user/100000/single-instance-locks/usr/bin/harbour-quartermaster/ and another re-install. No luck - Quartermaster hangs.
I then proceeded to try and investigate this from the command line, so I fired up harbour-quartermaster from a terminal - and then it did start and showed the installation wizard. I completed the configuration, entered the token again and got it connected to the new Home Assistant instance.
Unfortunately, this was not the end of it - when I closed Quartermaster again, I still could not start it by tapping on the icon - it just hangs. When I run it from the command line, it does start, but does not store the configuration - it shows the installation wizard, where IP and port are correctly filled in, but not the access token.
So, the question is: what do I need to do to actually start with a clean slate with Quartermaster, so I can configure it from scratch and use it normally from the icon afterwards?
I can confirm some similar behaviour on a X with 4.0.1.48.
At some point of testing Defender could not be started anymore by tapping the icon in launcher (no instance running, checked). But it did start from command line!
I did not investigate any further but reflashed (also due to other testing…).
Maybe worth a bug report?
Hi thanks for your feedback!
I think the trouble maker is the Sailfish Secrets part which stores tokens and / or my serialization of this stored data. At the moment I am rewriting the application core and noticed that too.
The problem seems to be that the app looses the access to this secret data and can not create a new one as long as the secret collection exist.
I will try to make a fast fix for this before proceeding with the new application core. Maybe a simple reset button in the setup wizard that removes at least the secrets collection and maybe the whole configuration.
New version is out with possibility to reset the stored secrets in Sailfish Secrets:
  1. on intro page of setup wizard
  2. in settings on page “Device Info”
Hope this helps!
Yes! I got it working again with the new version, thank you! However, there were two minor issues:
  • When I used Device info -> Reset, Quartermaster vanished (looked like a crash) - but at least the set-up wizard started again when starting the app again
  • When entering the new host information in the wizard (IP and port), I could not swipe left to go further - the swipe dot was greyed out. At some point after swiping back and forth and changing the IP once or twice it suddenly became active and I could continue. After that, everything worked fine.
Good to hear it helps!
  • I close the app when registration is deleted. This is the “normal behaviour”.
  • I will check this
Ah, that explains it. From a “simple user” point of view, I would appreciate some kind of warning, as I associate an app that “vanishes” with crashes and other “bad karma”… :grin: Other than that, I’m really happy! :+1:
