I am using galaxy buds as my wireless headphones, I didn’t really have a problem with them until I got on Sailfishos and the quality is way worse than my previous android device.
I am not sure if it’s the headphones fault or sailfishos/pulseaudio’s fault, I saw that it supports a2dp so it theory it should be fine, but at the same time the headphones worked fine on my old phone.
Also the volume is really low, and I am the type who listens at a pretty high volume usually, this is quite bothersome and pushing setting the sink volume to a higher volume makes it really distorted.
I can usually get over the other inconveniences, but audio quality is a pretty big thing for me and I want to be able to listen to decent quality on my phone.
