Bluetooth connection to car radio is not working correctly
REPRODUCIBILITY: every time
OS VERSION: 5.1.0.10
HARDWARE: Sony Xperia 10 III
UI LANGUAGE: de
REGRESSION:
The Bluetooth connection to the car is not stable.
After the first pairing, the signal strength from the phone is displayed and the message “Bluetooth Audio Connection Error” appears. However, I can still play music from my phone via Bluetooth in the car. Neither the artist nor the title is displayed. The name of the cell phone is also not displayed, instead there is simply nothing there (but that has always been the case).
When I leave the car and come back, the phone tries to connect and also shows “Connected”. The car display also shows the signal strength from the mobile phone and then the message “Bluetooth audio connection error”. But now I can’t play anything in the car. When I press play, the music comes out of the phone speaker. Making calls is possible, using the car’s speakerphone works.
So there is some kind of Bluetooth connection to the car, but not really. This was not the case under SFOS <=5.0. It had problems with my car occasionally, but most of the time the connection was automatic and displayed the title and artist.
  1. Pair the mobile with the car.
  2. Play music and enyoy it.
  3. Leave the car and get back later.
  4. The mobile connects to the car again.
  5. No music can be played
The car’s soundsystem plays music from the mobile, when pairing was successful.
The mobile connects to car’s bluetooth. I can make phone calls with the car’s hands free system. I cannot play music after the firts pairing of bluetooth.
Tested with and without “Bluetooth Car Mode” patch.
Tested with and without “AppSupport Bluetooth (beta)” App from Jolla.
Otherwise many patches and repositories from openrepos.
The car is a Ford B-Max with a Sony car radio. I followed the steps here: Collect Bluetooth Logs | Sailfish OS Documentation for the logs. The output of journal.log for bluetoothd ar in the following post.
I hope this can be fixed.
journal.log (shortened):
-- Logs begin at Fri 2025-11-07 12:09:59 CET, end at Fri 2026-06-12 09:22:07 CEST. --
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x2347e30: Get_Capability_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:session_cb()
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received  GET_CAPABILITIES_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x23491a0: Get_Capability_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:session_cb()
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received  GET_CAPABILITIES_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x23491a0: Get_Capability_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234a610: Get_Capability_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234a610: Get_Capability_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234bb30: Get_Capability_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234bb30: Get_Capability_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received SET_CONFIGURATION_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_setconf_ind() Source 0x2343610: Set_Configuration_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_get() sep 0x2328d00 session 0x23564f0
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x2374560: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x2374560: ref=2
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received SET_CONFIGURATION_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesAdded
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_setconf_ind() Source 0x2343610: Set_Configuration_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_get() sep 0x2328d00 session 0x23564f0
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.SetConfiguration
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/media.c:media_endpoint_async_call() Calling SetConfiguration: name = :1.6359 path = /MediaEndpoint/A2DPSource/sbc
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x2374560: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x2374560: ref=2
Jun 12 09:20:53 Stippens bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesAdded
Jun 12 09:20:53 Stippens bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.SetConfiguration
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/media.c:media_endpoint_async_call() Calling SetConfiguration: name = :1.6359 path = /MediaEndpoint/A2DPSource/sbc
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=3
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: IDLE -> CONFIGURED
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x2374560: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x2374560: ref=0
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_free() 0x2374560
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=2
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=3
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: IDLE -> CONFIGURED
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x2374560: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x2374560: ref=0
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_free() 0x2374560
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=2
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received OPEN_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:open_ind() Source 0x2343610: Open_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received OPEN_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:open_ind() Source 0x2343610: Open_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:confirm_cb() AVDTP: incoming connect from 14:0D:4F:48:3B:F9
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:confirm_cb() AVDTP: incoming connect from 14:0D:4F:48:3B:F9
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() Flushable packets enabled
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() sk 25, omtu 2688, send buffer size 106496
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() Flushable packets enabled
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CONFIGURED -> OPEN
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: disconnected -> connected (0)
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: plugins/policy.c:service_cb() Added a2dp-sink reconnect 1
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTING -> SINK_STATE_CONNECTED
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/transport.c:transport_update_playing() /org/bluez/hci0/dev_14_0D_4F_48_3B_F9/fd0 State=TRANSPORT_STATE_IDLE Playing=0
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() sk 25, omtu 2688, send buffer size 106496
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CONFIGURED -> OPEN
Jun 12 09:20:53 Stippens bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: disconnected -> connected (0)
Jun 12 09:20:53 Stippens bluetoothd[51449]: plugins/policy.c:service_cb() Added a2dp-sink reconnect 1
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTING -> SINK_STATE_CONNECTED
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/transport.c:transport_update_playing() /org/bluez/hci0/dev_14_0D_4F_48_3B_F9/fd0 State=TRANSPORT_STATE_IDLE Playing=0
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received CLOSE_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:close_ind() Source 0x2343610: Close_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: OPEN -> CLOSING
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received CLOSE_CMD
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:close_ind() Source 0x2343610: Close_Ind
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: OPEN -> CLOSING
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:transport_cb()
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:transport_cb()
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CLOSING -> IDLE
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CLOSING -> IDLE
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_destroy() sep 0x2328d00 stream 0x2355aa0
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_destroy() sep 0x2328d00 stream 0x2355aa0
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.ClearConfiguration
Jun 12 09:20:53 Stippens bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.ClearConfiguration
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:53 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:set_disconnect_timer() timeout 1
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=1
Jun 12 09:20:53 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:set_disconnect_timer() timeout 1
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:connection_lost() Disconnected from 14:0D:4F:48:3B:F9
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTED -> SINK_STATE_DISCONNECTED
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: connected -> disconnected (0)
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:channel_remove() chan 0x23365e0
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:54 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_free() 0x23564f0
Jun 12 09:20:54 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:54 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:connection_lost() Disconnected from 14:0D:4F:48:3B:F9
Jun 12 09:20:54 Stippens bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTED -> SINK_STATE_DISCONNECTED
Jun 12 09:20:54 Stippens bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: connected -> disconnected (0)
Jun 12 09:20:54 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:channel_remove() chan 0x23365e0
Jun 12 09:20:54 Stippens bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:54 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:54 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:54 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_free() 0x23564f0
Jun 12 09:20:54 Stippens kernel: rpmh_rsc_send_data: 103 callbacks suppressed
Jun 12 09:20:54 Stippens kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:confirm_cb() AVDTP: incoming connect from 14:0D:4F:48:3B:F9
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:confirm_cb() AVDTP: incoming connect from 14:0D:4F:48:3B:F9
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_DISCONNECTED -> SINK_STATE_CONNECTING
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: src/device.c:btd_device_add_uuid() device SYNC, uuid 0000110d-0000-1000-8000-00805f9b34fb
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: src/device.c:device_probe_profiles() Probing profiles for device 14:0D:4F:48:3B:F9
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: plugins/sailfish-exclude.c:filter_cb()
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_connect_cb() AVDTP: connected signaling channel to 14:0D:4F:48:3B:F9
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_connect_cb() AVDTP imtu=672, omtu=2688
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_register_remote_sep() seid 1 type 1 media 0 delay_reporting false
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:register_remote_sep() Found remote SEP: /org/bluez/hci0/dev_14_0D_4F_48_3B_F9/sep1
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:load_remote_sep() LastUsed: lseid 2 rseid 1
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:set_disconnect_timer() timeout 1
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesAdded
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_DISCONNECTED -> SINK_STATE_CONNECTING
Jun 12 09:20:56 Stippens bluetoothd[51449]: src/device.c:btd_device_add_uuid() device SYNC, uuid 0000110d-0000-1000-8000-00805f9b34fb
Jun 12 09:20:56 Stippens bluetoothd[51449]: src/device.c:device_probe_profiles() Probing profiles for device 14:0D:4F:48:3B:F9
Jun 12 09:20:56 Stippens bluetoothd[51449]: plugins/sailfish-exclude.c:filter_cb()
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_connect_cb() AVDTP: connected signaling channel to 14:0D:4F:48:3B:F9
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_connect_cb() AVDTP imtu=672, omtu=2688
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_register_remote_sep() seid 1 type 1 media 0 delay_reporting false
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:register_remote_sep() Found remote SEP: /org/bluez/hci0/dev_14_0D_4F_48_3B_F9/sep1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:load_remote_sep() LastUsed: lseid 2 rseid 1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:set_disconnect_timer() timeout 1
Jun 12 09:20:56 Stippens bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesAdded
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:session_cb()
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received DISCOVER_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:session_cb()
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received DISCOVER_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received  GET_CAPABILITIES_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x2343610: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received  GET_CAPABILITIES_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x2343610: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x2347e30: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x2347e30: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x23491a0: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x23491a0: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234a610: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234a610: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234bb30: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_getcap_ind() Source 0x234bb30: Get_Capability_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received SET_CONFIGURATION_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_setconf_ind() Source 0x2343610: Set_Configuration_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_get() sep 0x2328d00 session 0x23564f0
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x23764c0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x23764c0: ref=2
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received SET_CONFIGURATION_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.SetConfiguration
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/media.c:media_endpoint_async_call() Calling SetConfiguration: name = :1.6359 path = /MediaEndpoint/A2DPSource/sbc
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:endpoint_setconf_ind() Source 0x2343610: Set_Configuration_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_get() sep 0x2328d00 session 0x23564f0
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x23764c0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_ref() 0x23764c0: ref=2
Jun 12 09:20:56 Stippens bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.SetConfiguration
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/media.c:media_endpoint_async_call() Calling SetConfiguration: name = :1.6359 path = /MediaEndpoint/A2DPSource/sbc
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=3
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=3
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: IDLE -> CONFIGURED
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: IDLE -> CONFIGURED
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x23764c0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x23764c0: ref=0
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:setup_free() 0x23764c0
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=2
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x23764c0: ref=1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_unref() 0x23764c0: ref=0
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:setup_free() 0x23764c0
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=2
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received OPEN_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:open_ind() Source 0x2343610: Open_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received OPEN_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:open_ind() Source 0x2343610: Open_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() Flushable packets enabled
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() sk 25, omtu 2688, send buffer size 106496
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CONFIGURED -> OPEN
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: disconnected -> connected (0)
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: plugins/policy.c:service_cb() Added a2dp-sink reconnect 1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() Flushable packets enabled
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTING -> SINK_STATE_CONNECTED
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/transport.c:transport_update_playing() /org/bluez/hci0/dev_14_0D_4F_48_3B_F9/fd0 State=TRANSPORT_STATE_IDLE Playing=0
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:handle_transport_connect() sk 25, omtu 2688, send buffer size 106496
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CONFIGURED -> OPEN
Jun 12 09:20:56 Stippens bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: disconnected -> connected (0)
Jun 12 09:20:56 Stippens bluetoothd[51449]: plugins/policy.c:service_cb() Added a2dp-sink reconnect 1
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTING -> SINK_STATE_CONNECTED
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/transport.c:transport_update_playing() /org/bluez/hci0/dev_14_0D_4F_48_3B_F9/fd0 State=TRANSPORT_STATE_IDLE Playing=0
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received CLOSE_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:close_ind() Source 0x2343610: Close_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: OPEN -> CLOSING
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_parse_cmd() Received CLOSE_CMD
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:close_ind() Source 0x2343610: Close_Ind
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: OPEN -> CLOSING
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:transport_cb()
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CLOSING -> IDLE
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_destroy() sep 0x2328d00 stream 0x234bc40
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:transport_cb()
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.ClearConfiguration
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_stream_set_state() stream state changed: CLOSING -> IDLE
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:56 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:a2dp_stream_destroy() sep 0x2328d00 stream 0x234bc40
Jun 12 09:20:56 Stippens bluetoothd[51449]: [:1.6359:method_call] < org.bluez.MediaEndpoint1.ClearConfiguration
Jun 12 09:20:56 Stippens bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:56 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:58 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_ref() 0x23564f0: ref=2
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:connection_lost() Disconnected from 14:0D:4F:48:3B:F9
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTED -> SINK_STATE_DISCONNECTED
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: connected -> disconnected (0)
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/a2dp.c:channel_remove() chan 0x2332590
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:58 Stippens bluetoothd[51449]: bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_free() 0x23564f0
Jun 12 09:20:58 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:connection_lost() Disconnected from 14:0D:4F:48:3B:F9
Jun 12 09:20:58 Stippens bluetoothd[51449]: profiles/audio/sink.c:sink_set_state() State changed /org/bluez/hci0/dev_14_0D_4F_48_3B_F9: SINK_STATE_CONNECTED -> SINK_STATE_DISCONNECTED
Jun 12 09:20:58 Stippens bluetoothd[51449]: src/service.c:change_state() 0x232ff60: device 14:0D:4F:48:3B:F9 profile a2dp-sink state changed: connected -> disconnected (0)
Jun 12 09:20:58 Stippens bluetoothd[51449]: profiles/audio/a2dp.c:channel_remove() chan 0x2332590
Jun 12 09:20:58 Stippens bluetoothd[51449]: [signal] org.freedesktop.DBus.ObjectManager.InterfacesRemoved
Jun 12 09:20:58 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=1
Jun 12 09:20:58 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_unref() 0x23564f0: ref=0
Jun 12 09:20:58 Stippens bluetoothd[51449]: profiles/audio/avdtp.c:avdtp_free() 0x23564f0
I had to delete and re-pair as this update (5.1.0.10) did not connect to the car. Previous updates have not required a re-pair.
The name of the phone in the cars bluetooth settings is now blank.
(without appsupport-bluetooth beta installed)
This is new bug for me, but I am not sure when it arose, as I paired the car multiple updates ago.
My X10III, v5.1.0.11 works ok in general.
Faced a “connected but not working” once, with a loudspeaker, after being used fine on the carkit. Couldn’t reproduce.
I don’t have the empty BT device name - but I had it long ago:
My phone completely froze at the beginning of the week and wouldn’t work anymore. I reflashed it with sfos 5.1.0.11 on Android 11, and the Bluetooth issues with the car connection disappeared. The touch controls also react to all touches.
