When trying to install any app from the storeman through the web and install it in my sony 10II , I cant find any arqutecture to work. Which one should I use?
The Xperia 10 II needs packages for the aarch64 architecture. Most apps are not updated with this yet. So using the storeman app is probably a good idea, as it will choose the correct architecture. For those that doesn’t have it yet, there will be no option to install.
thanks for the answer. you rocked. I had to refresh the system before been able to install it with pkcon refresh
